replacing opti
Old Aug 11, 2002 | 07:34 PM
republicanhunk's Avatar
republicanhunk
Default replacing opti
a friend and i are about to replace my opti, any suggestions for a 93 would be appreciated. (my friend has replaced an opti in his firebird and is also a vette brother). you just never know of any surprises in there. thanks :)
Old Aug 11, 2002 | 08:17 PM
robert kirk's Avatar
robert kirk
Default Re: replacing opti (republicanhunk)
i have done this several times and its pretty straight forward.. make sure to line up the drive. i would also check the water pump now would be the time to change it. i also took a peice of vacc tubing about 6 feet long and ran it up under the finder and put a open end fuel filter on it. this will let the opti breath and not pull in water. don't know if it will help but from the looks of the inside of the opti i took off it can't hurt. robert
Old Aug 11, 2002 | 08:27 PM
Kdrhpe's Avatar
Kdrhpe
Replace the water pump and make sure you remove all the gasket material before putting on the new ones. Use a universal joint on the middle bolt on the drivers side.
Old Aug 11, 2002 | 08:34 PM
republicanhunk
Default Re: replacing opti (robert kirk)
good advice. actually i had the opti replaced 2 months ago when the water pump failed so thats new too. the hose trick, i did the very same thing already with the exception of the filter...great idea!
Old Aug 11, 2002 | 08:37 PM
James94LT1's Avatar
James94LT1
:confused: And its bad already? :confused: :smash:
Old Aug 11, 2002 | 08:39 PM
republicanhunk
Default Re: replacing opti (James94LT1)
it was replaced by a mechanic in gnaw bone indiana. yes im serious. i wont let anyone touch my car anymore. cant trust anyone. these guys looked straight out of Deliverence :)
Old Aug 12, 2002 | 11:21 AM
konroh's Avatar
konroh
Default Re: replacing opti (Kdrhpe)
Started pulling off my waterpump last night. Will a universal joint let me get to the last bolt without having to remove the pulley on the power steering pump?
Old Aug 12, 2002 | 11:27 AM
GlockLT4's Avatar
GlockLT4
Default Re: replacing opti (konroh)
Yes, it should. If I remember right, I used both a u-joint as well as a swivel.
Old Aug 12, 2002 | 11:31 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: replacing opti (Glock'94)
I've found that you can get it off by just not using a deep well socket. I haven't yet needed a universal.
Old Aug 12, 2002 | 03:05 PM
Mac78and2K's Avatar
Mac78and2K
What sealer, if any, do you use between the water pump and gasket or betweeen the gasket and block? What kind is best? Glock94, how is your car recovering?
-Thanks
Old Aug 17, 2002 | 08:11 PM
republicanhunk
Default Re: replacing opti (Mac78and95)
we got her running yesterday.. its so good to have her back. we used a sealent specifically used for coolant applications. we also replaced the thermostat. we think it froze up after drying out over a period of several days. the only real problems we had is we bent the screw on the pulley puller (ended up sawing it off) and we accidentally got the plug wires wrapped around the belt. all is good now :)
To replacing opti
