My Dash Blinks
Old Mar 22, 2015 | 05:34 PM
VetosVet's Avatar
VetosVet
Cruising
Default My Dash Blinks
First off I must confess that that while I am an experienced hobby mechanic I have always owned a competitors cars. That being so I don't understand what Vet abbreviations mean. so if you use them please write out what it means as well. For instance I have seen the Abbreviation "DIC" Which means to me Double inter-cooler. I was reading about dash problems. So I know my understanding and what was meant is different. To my problem:
History: I recently bought a 1984 Vet with a totally blown motor. I replaced it and am now fixing other things. There is one thing that I am unsure about. There are I think 4 tan connectors to the distributor Tach terminal. I have one left over. Can anyone help me with where these all go?
Symptoms: Now that the motor is in the car I have discovered that the digital dash Flashes when the motor is revving between 1200 and 2400 rpm. (Aside: it idles at 900 rpm which I think is high.) Outside those ranges it is lit constantly except for the coolant temp gauge is dark and never reads the temperature. The other functions of that gauge also don't work. I only mention the next problem as it might be related. The stereo turns on but there is now sound at the speakers.
Any help is appreciated.
Old Mar 22, 2015 | 05:40 PM
antfarmer2's Avatar
antfarmer2
Check the ground on the drivers side I think it is by the front of the door under the carpet and one on the same side of the engine
Old Mar 23, 2015 | 12:16 AM
Cliff Harris's Avatar
Cliff Harris
DIC is Driver Information Center. This guy:
Old Mar 24, 2015 | 01:57 PM
1984Z51auto's Avatar
1984Z51auto
The extra distributor connection is for test equipment. The speakers each have dedicated amps that turn on through a relay that may be toast (it is a BOSE Radio, right??). There are 4 halogen bulbs that light the dash... is the problem that one is burned out on the TEMP gauge or is the gauge display inop?
Old Mar 24, 2015 | 08:24 PM
VetosVet's Avatar
VetosVet
Cruising
Default Thanks. Still working on it.
Nice to know what DIC is, and That I did not miss something on the extra tach lead at the Distributor. When I look at the stereo I know to check for that relay.
To clarify the problem with the dash is that the whole digital dash display blinks at the specified RPM even the gauge areas that don't work. Every pixel lights up so all letters and numerals look like "8". Then it all goes blank and then repeats at about 3-5 cycles per second. When out of that RPM range the coolent temp is black, Every part of it. The areas of the dash are lit and function just fine.
Old Mar 25, 2015 | 01:36 PM
Robert Perkins's Avatar
Robert Perkins
Default Dash blinks
What you are seeing is the dash is going into test mode. This can be caused by an intermittant ground, and intermittant power input or a crack in one of the circuitboards in the dash. As someone sugested check the gounds also check the three fuses for the dash located in the fuse panel pull them out and visually inspect. If you can not find the problem I can repair it for you. Go to my web site www.advancedelectronics.org for more information and removal instructions.
Old Mar 26, 2015 | 01:13 AM
Cliff Harris
The readouts in the center of the cluster are controlled by 4 switches to the left of the DIC. If one of those switches is in the center position (off) then the corresponding display will be dark.
Old Mar 27, 2015 | 02:14 AM
VetosVet's Avatar
VetosVet
Cruising
that's not the problem, Cliff, but if a switch is bad that could be it. Thanks it gives me another clue. Today I just put the repaired inner fender back in. Sunday is when I'll start on the Dash. thanks all for the hints.
Old Apr 7, 2015 | 09:23 PM
VetosVet's Avatar
VetosVet
Cruising
the ground is good. I cleaned it to be sure. I cleaned all the switches and tested for continuity. That's all good. So the dash is going to advanced electronics.
Old Apr 8, 2015 | 02:34 AM
gerardvg's Avatar
gerardvg
Batee has the common failure kits on ebay, i had a bad connector on mine that made the display go blank and back to normal from driving over rough terrain. My bad for taking the vette off road
See his services on the http://www.batee.com/
http://www.ebay.com/itm/Backlight-Repair-Kit-Connector-C4-Corvette-Digital-Cluster-Gauge-Instrument-Dash-/111632568157?hash=item19fdd1cf5d
http://www.ebay.com/itm/Xenon-Bulb-Kit-C4-Corvette-Digital-Cluster-Gauge-Instrument-Panel-Gauge-Dash-/121612920654?hash=item1c50b1e74e
http://www.ebay.com/itm/Photocell-Repair-Kit-C4-Corvette-Digital-Cluster-Gauge-Instrument-Panel-Dash-/121614846194?hash=item1c50cf48f2
Old Apr 29, 2015 | 02:19 AM
VetosVet's Avatar
VetosVet
Cruising
Default Robert Perkins...
...was right. We sent the dash to him and he fixed it. We also found that the tach input near the distributor needed to be cleaned and tightened up. Thiose 2 things fixed it. Now to figure out why it backfires intermittently.
Kudos to Robert Perkins.
To My Dash Blinks
