Timing Help!!
Old Mar 23, 2015 | 05:33 PM
eliebarcham's Avatar
eliebarcham
Default Timing Help!!
Hey guys
My timing chain snapped off about a year ago on my 86 vette and my mechanic got it replaced and ran again. Today I was just curious to check with an inductive timing light what degree I am running (expecting 6°BTDC). I cranked the engine up and aimed the light at the balancer and found that the marker was about two centimeters away from the timing plate? Is that normal? Doesnt need timing adjustment? The car seems to run normal.
Please help
Thank you
Old Mar 23, 2015 | 06:22 PM
DanielRicany's Avatar
DanielRicany
Should be around 20* advance at idle when the EST connector is plugged in. When the EST connector is not plugged in, it should be 6*.
Old Mar 23, 2015 | 09:45 PM
eliebarcham
That helped me a lot! Thank you veryy muchhh
Old Mar 23, 2015 | 09:47 PM
eliebarcham
Is true if I advance it to 8°BTDC, I do get a little more low end torque?
Old Mar 24, 2015 | 01:37 PM
1984Z51auto's Avatar
1984Z51auto
It is car specific... you might also get a little ping and activate the computer to pull timing. Try it and see.
To Timing Help!!
