Well, This is interesting.
Old Mar 23, 2015 | 07:26 PM
ch@0s's Avatar
ch@0s
Default Well, This is interesting.
My horn quit working. After some checking I realized my steering column is no longer grounded. If I run a jumper from the batt to the center opf the steering column it works.
Old Mar 24, 2015 | 12:47 AM
ch@0s's Avatar
ch@0s
Its all good, ground wire was cut.
Old Mar 24, 2015 | 01:12 PM
JackDidley's Avatar
JackDidley
If the horn is the only thing affected thats sort of surprising.
Old Mar 24, 2015 | 01:21 PM
ch@0s's Avatar
ch@0s
The PO had tapped into the Horn ground to add an alarm. I took that out like 8 years ago. The T tap he put in there must have cut through it over time or I tugged on it hard enough that it broke where it was tapped into.
Old Mar 24, 2015 | 01:22 PM
DGXR's Avatar
DGXR
The horn was working, then it stopped working, and you find the ground wire was cut?
Who would do that to your car?
To Well, This is interesting.
