How to stop scratching windows?
Old Aug 12, 2002 | 03:59 PM
NavyVet's Avatar
NavyVet
Default How to stop scratching windows?
My '89 has scratches on the windows in both doors. I can't see what caused (or maybe is continuing to cause) it. Both doors had new window weatherstrips (top - inner and outer) installed 3 months ago before I bought it. Any help on where to look and what to do to eliminate the source is most greatly appreciated. Paul
Old Aug 12, 2002 | 04:01 PM
rocketfinger's Avatar
rocketfinger
Default Re: How to stop scratching windows? (NavyVet)
Worn weather strips were the culprit on mine, nothing else on the outside contacts the glass. Now I'm looking for a decent glass rouge.
Are you sure your scratches aren't pre-weatherstrip-replacement?
Old Aug 12, 2002 | 05:17 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: How to stop scratching windows? (rocketfinger)
Same here. I got a few small rocks in there as well and it really scratched them up... :mad I went ahead and ripped all the strip out to stop things from getting stuck in there and scratching the glass for the time being.
Old Aug 12, 2002 | 06:41 PM
Siveck's Avatar
Siveck
Check the felt covered adjustment pads inside the door. These will scratch the glass sometimes. I think there are 2 on each side. :)
Old Aug 12, 2002 | 06:43 PM
Siveck's Avatar
Siveck
Also, there are metal pieces that hold the top of the door panel on, these could also be the culprit- adjust pads to correct. :)
Old Aug 12, 2002 | 07:07 PM
c4md's Avatar
c4md
I'll bet if you check the scratches are right were the weatherstrips rivet to the door. If the rivets stick out some they can scratch the glass. I had to file mine down a bit and then I glued some felt over the rivet.
Old Aug 12, 2002 | 08:20 PM
NavyVet's Avatar
NavyVet
Default Re: How to stop scratching windows? (c4md)
Thanks for all the good suggestions. I will take it apart Saturday. Paul
Old Aug 12, 2002 | 09:16 PM
Glasman66's Avatar
Glasman66
I took care of the problem for good on mine. The felt pads need to on the glass. If the felt is gone they need to be replaced. The rivits are aluminum so they sould not scratch the glass unless they are really screwed up. They will lease an silver streak on the window if they are rubbing.
When I remoed mine the felt had just fallen off the metal part. So I just epoxied it back on. I also replaced both door glasses too.
Old Aug 12, 2002 | 10:14 PM
CSM87's Avatar
CSM87
Default Re: How to stop scratching windows? (Glasman66)
The felt adjustment pads did my drivers door glass in on the outside. ... :mad
To How to stop scratching windows?
