Self Aligning Roller Rockers
Old Apr 3, 2015 | 03:58 PM
ClaudioC4's Avatar
ClaudioC4
Default Self Aligning Roller Rockers
Hello:
I have a 1985 with a stock 350. I recently purchased a set of Edelbrock 6061 aluminum heads. A friend has a set of comp cam gold 1.6 roller rockers that I can have. They are self-aligning, can they be used with my set up?
I am going to run the stock cam until I can find someone to install the cam since its a job that I have never done and am afraid to tackle.
Old Apr 3, 2015 | 08:06 PM
C409's Avatar
C409
........ Should be fine ... its always a good idea to check all your valve clearances (rocker to spring and retainer to valve seal) when changing lift (1.6:1 ratio) , but the change is very slight on a stock lift cam ... you should , however , check for correct push rod length when switching from slipper rockers to full rollers ... the Crane Golds are among the best aluminum rockers out there ... and you got 'em at the best possible price ........... self-aligning rockers use NO guide plates and are recommended for hydraulic cams only
Old Apr 3, 2015 | 08:11 PM
ClaudioC4's Avatar
ClaudioC4
It is a new installation so I will use new pushrods. My 85 is hydraulic flat tappet, so I assume that I should be ok?
Old Apr 3, 2015 | 08:19 PM
ghoastrider1's Avatar
ghoastrider1
just make sure your heads do not have guide plates..
Old Apr 3, 2015 | 08:57 PM
WW7's Avatar
WW7
His rockers are Comp cams , not Crane Golds...I agree that he will probably need different length push rods from stock, when you change ratio you usually have to use a different length ...WW
Old Apr 3, 2015 | 09:37 PM
1984Z51auto's Avatar
1984Z51auto
Default Check valve cover to rocker interfearence
Check to be sure that the bigger lifter body/higher lift does not put the rocker into the valve covers. The drip tabs on the older cast covers can be an issue.
Old Apr 4, 2015 | 12:18 AM
mtwoolford's Avatar
mtwoolford
if your heads have large round holes where the push rod passes through you can use either guide plates or self aligning rockers;
if your heads have narrow slots where the push rods pass through, these narrow slots serve the same purpose as guide plates and you should not use self aligning rockers
To Self Aligning Roller Rockers
