HELP ---just changing ignition switch
Old Apr 5, 2015 | 02:27 PM
mercury2's Avatar
mercury2
8th Gear
Default HELP ---just changing ignition switch
changing out the old ignition switch, easy hah, everything was going ok how does the telescopic steering wheel shaft stay in place r what holds in lock in? when I pulled it out I didn't know there was a small rod inside the shaft plus shaft key on the end of it, when I picked it up to put it back in and the small rod fell out and the shaft key fell offany help please, Thank You much
Old Apr 5, 2015 | 02:32 PM
antfarmer2's Avatar
antfarmer2
Look at the top of the page first sticky
Old Apr 5, 2015 | 02:47 PM
mercury2's Avatar
mercury2
8th Gear
Default Thanks Antfarm2 but no
I guess a lot of difference between 1985 and a 1991.
Old Apr 5, 2015 | 02:49 PM
antfarmer2's Avatar
antfarmer2
I guess a lot of difference between 1985 and a 1987.
Worth a try never done it and have a 94 hang on a lot of smart folk here but is Easter
Old Apr 5, 2015 | 02:52 PM
mercury2's Avatar
mercury2
8th Gear
Default Antfarmer2
Thank for trying
Old Apr 5, 2015 | 09:25 PM
mercury2's Avatar
mercury2
8th Gear
Default IgnitionSwitch----
I finally got it back together, some time you just have step back and think.
Old Apr 5, 2015 | 10:04 PM
antfarmer2's Avatar
antfarmer2
Good job
To HELP ---just changing ignition switch
