window problem
Old Apr 7, 2015 | 12:54 PM
plb0426's Avatar
plb0426
1st Gear
Default window problem
I have a 1996 Corvette and the passenger window switch in inop. Both windows were working with the driver's side switch. I took the car into a Chevrolet dealership...they took the passenger switch out and cleaned the contacts (before ordering a replacement switch). When they reinstalled the passenger switch, the window still didn't work....and....now the driver's side window is slow and jerks....any ideas???
Old Apr 7, 2015 | 04:32 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Default subbing as my driver window did same
thing then stopped. dont mess with the driver window it can get stuck down.
Old Apr 8, 2015 | 02:07 AM
gerardvg's Avatar
gerardvg
Slam the door while holding the window up or down button, it will work again.
This is a common problem wilh the wiring Connector being pulled to one side making a bad connection, slamming the door will make it work for a while. You have to remove the door panel and aluminum panel in door to access the connector/window motor.
The factory wiring is on the short side, it tugs at the connector.
Good luck
To window problem
