Huge Disc on Water Pump?
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hey all with the better weather in southern ohio I am finally getting the chance to go over my 88 Vette? What in the world is this huge disc on the front of the water pump? I have a few TPI F body's and they never had this............any down side to removal?
Brian Felts
Brian Felts
![](/forums/images/ranks/11k.gif)
If I recall correctly it was intended to dampen vibrations when the AC is on. Many remove it without issue. I believe on the earlier cars it was quite heavy (10 lbs or so I think). Although mine was the newer, lighter version, I removed it about 10 years ago and have seen no ill effects.
Do a search for "frisbee" and you'll see plenty of reading material.
![](/forums/images/ranks/3k-4k.gif)
I thought everyone knew about the Frisbee. Take it off but keep it handy. I removed it off my 88 6 years ago when I had to replace the original water pump. So far so good. I re-used the same bolts plus lock washers.
Received 1,427 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
It is called the frisbee, it was meant to dampen engine vibrations when the AC compressor kicks on.
Take it off.
Take it off.
