brake/abs problem
Old Jun 6, 2015 | 11:33 PM
Cliff Harris's Avatar
Cliff Harris
This thread might apply in your case:
https://www.corvetteforum.com/forums...post1570563275
This is the solution (post #316!!!) of a LONG thread on hard brake pedal problems.
Old Jun 6, 2015 | 11:50 PM
desertmike1's Avatar
desertmike1
This could also be corrosion inside of the calipers, and the pistons aren't moving freely. A couple years ago I disassembled my Calipers and used a (Scotch bright) pad to clean the internal Caliper Bore's and pistons alike. Afterward I had a nice feeling peddle W/out any brake drag.
just a thought!
Old Jun 7, 2015 | 07:35 AM
WVZR-1's Avatar
WVZR-1
I like the "booster check idea" that's free and nearly effortless, the brake hoses are I believe to be considered maintenance so that's nearly a "to do" anyway, Cliff's suggested read is certainly interesting, I had a friend that whenever he had a customers car with a braking issue if it was an ABS car the first thing he did was "exercise" the system and lastly considering the disassembly of the calipers for inspection BUT it's certainly a potential situation though I think the least likely for your symptoms.
Your car you mention does the ABS check at "KEY ON/START UP" so ........
