Best method for finding vaccum leaks?
Old Apr 14, 2015 | 07:20 AM
jodester's Avatar
jodester
St. Jude Donor '14
Default Best method for finding vaccum leaks?
Whats best way to find vaccum leaks? is it just visual, looking for kinks or worn spots, or is there another test? specifically the L98
Old Apr 14, 2015 | 07:59 AM
WW7's Avatar
WW7
The 2 methods I have seen mentioned on this site are::
#1 Use a propane torch (not lit of course) to run around the areas of the engine that may have leaks, connections , gaskets, hoses, etc ....
#2 Use carb cleaner to spray around the same areas as above to see if there are leaks...On both methods the idle of the engine will pick up if there's a leak, also you are using flammable substances so be very careful that you don't start a fire...I believe some pro auto shops have a smoke machine they use for detecting air leaks....WW
Old Apr 14, 2015 | 10:17 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
#3 youtube scotty kilmer vacum leak cigar.....this is a fun method. i found mine this way. i then confirmed it with some carb cleaner.
Old Apr 14, 2015 | 10:26 AM
agillings's Avatar
agillings
I used the visual method, trace them out and carb cleaner. 2 benefits you will find leak and know your vac system and be able to verify leak
Old Apr 14, 2015 | 11:04 PM
Cliff Harris's Avatar
Cliff Harris
The Scotty Kilmer YouTube video is here:
Vacuum leaks can be very subtle and in places that are not at all obvious. One was found in another forum where the gasket was missing under the throttle body top plate.
Old Apr 15, 2015 | 12:41 PM
383vett's Avatar
383vett
This plate mounted on the plenum in place of the throttle body will help locate vacuum leaks. It will take some effort is worth it if a leak is hard to discover. Back off the intake rockers which will seal the intake system. Using a smoker device, inject smoke through the port in the plate. Watch for the source of the leak.
Old Apr 16, 2015 | 03:46 PM
Christi@n's Avatar
Christi@n
How long do you smok the cigar to find it out?
I've tried to do it with cigarette instead cigar, i've puffed it all inside the TB and i'seen no vauum leaks
Old Apr 16, 2015 | 04:57 PM
WW7's Avatar
WW7
Sorry, but i've been told it only works using EL Producto Cigars...Cigarettes won't work ........WW
Old Apr 16, 2015 | 04:59 PM
patriotpa's Avatar
patriotpa
I write a check.
Best way I've found.
Old Apr 16, 2015 | 05:04 PM
VikingTrad3r
Oil Producer
pull the intake accordian hose off the tb and duct tape over the tb opening. then remove the break booster line and blow in. not sure about cigarettes.
Old Apr 26, 2015 | 02:10 PM
DanZ51's Avatar
DanZ51
I've done this several times I'll add this: disconnect the IAC plug before trying this. The ECM sees any RPM changes and corrects the IAC very quickly. Propane or Carb Cleaner won't change the RPM enough to notice if the ECM is doing it's job. Yes you'll probably set a code.
I big vacuum leak on my '86 was the throttle body shaft, so removing it to check for leaks kinda negates that part of a smoke test.
Old Apr 27, 2015 | 09:41 AM
jimmers's Avatar
jimmers
Originally Posted by patriotpa
I write a check.
That takes all the fun out of it!
Old Apr 27, 2015 | 10:38 AM
_ski_dwn_it's Avatar
_ski_dwn_it
Best way is with starter fluid and with a nozzle for direct spraying. As soon as you hit a leak area you will hear the car's RPM jump up and then go back down as it burns off the starter fluid. You can then methodically move around the area and pinpoint the exact source.
Its quick, easy, and reliable. Just be sure to be safe as the stuff is flamible. but it only takes a very small amount to cause the RPMs to change a few hundred and it is very noticable. It sounds like you "blipped" the throttle. And with each squirt it will repeat so you can make sure it was not your imagination.
Old Apr 27, 2015 | 07:29 PM
reg_255's Avatar
reg_255
My Dad was a Cigar salesman in the 70ies and sold EL Producto Cigars.
To Best method for finding vaccum leaks?
