Won't crank
Old Apr 15, 2015 | 09:22 PM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
Default Won't crank
My 91 with an L98 started fine a while ago but I shut it off and it would not crank. Everything worked except the starter. After it sat for about 20 min. it started fine. Could the problem be in the security system?
PA
Old Apr 15, 2015 | 09:26 PM
antfarmer2's Avatar
antfarmer2
PA
My 94 did that and got worse tryed my other key never did it again had a new key made
Old Apr 15, 2015 | 09:34 PM
Pa'svette's Avatar
Pa'svette
I tried both keys. It happened once before a couple years ago.
Thanks.
Old Apr 15, 2015 | 09:39 PM
antfarmer2's Avatar
antfarmer2
Thanks.
Clean the chips off good and get some caned air computer cleaner for the ing also you have to let it reset before useing the other key
Old Apr 15, 2015 | 09:43 PM
Pa'svette's Avatar
Pa'svette
I'll try that.
PA
Old Apr 15, 2015 | 09:47 PM
jv9999's Avatar
jv9999
Another common problem is a failing starter inhibit relay.
Old Apr 15, 2015 | 09:53 PM
Pa'svette's Avatar
Pa'svette
Where is that located
PA
Old Apr 17, 2015 | 03:12 PM
Pa'svette's Avatar
Pa'svette
Thanks guys. Found the relay and replaced it. Also cleaned the key.
PA
To Won't crank
