Part Throttle Power Issue
Old Apr 16, 2015 | 10:07 PM
nickgost's Avatar
nickgost
Default Part Throttle Power Issue
So my 92 m6 vette started to have a really weird issue after I replaced a bunch of parts. I pulled off the car a bad ICM, two different sets of plug wires, a MSD Streetfire coil and autolite plugs that were gapped at .060.
I then replaced them with Taylor wires, new Icm, MSD Blaster Coil, and NGK plugs gapped at .050. I also did the throttle body coolant bypass......
Now anytime I'm at part throttle the car seems to be struggling, it even seems that as I let off the throttle it gets a small boost of power. But when I am at WOT it runs like a raped ape. So basically Its struggling to move out, or its roasting tire. UNLESS its above 3k rpm sometimes it kicks in at 3.5k. once its above that RPM it runs great at all throttle positions. It almost feels like it has no timing until that RPM, and as you cross that line it likes to wack your head into the headrest and **** off passengers.
Mods to car:
-Taylor 8mm wires
-Newish opti (doesnt feel like opti failure)
-NGK Plugs
-New ICM
-Coolant bypass
-K&N air filter
-De-restricted airbox
-Hooker Shortie Headers
-High Flow Cats
-Magnaflow resonator w. mufflers dumped
-and other stuff that doesn't affect the way the engine runs lol!
I really have no ideas at this point.... And the issue is pretty damn annoying.
Thanks in advance guys!
Old Apr 16, 2015 | 10:14 PM
antfarmer2's Avatar
antfarmer2
Mods to car:
-Taylor 8mm wires
-NGK Plugs
-New ICM
-Coolant bypass
-K&N air filter
-High Flow Cats
What about the o2 sensors
Old Apr 16, 2015 | 10:24 PM
nickgost's Avatar
nickgost
That is an option, but why would RPM or going WOT change O2 sensor feedback?
Old Apr 16, 2015 | 10:28 PM
antfarmer2's Avatar
antfarmer2
Mine were old and tired puter tried to fix but would falter no codes put new in and what a differance
Old Apr 16, 2015 | 10:31 PM
nickgost's Avatar
nickgost
Maybe those will be my first try.... Now that I think about it my buddy snapped off the clip for the connector on the drivers side. hmmmmm
Old Apr 16, 2015 | 10:34 PM
antfarmer2's Avatar
antfarmer2
Let us know and thump your buddie :
To Part Throttle Power Issue
