C68
Old Apr 14, 2015 | 05:27 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Default C68
On my C68 climate control I ether have to set it to 90 for good heat or 60 for good cold air, if I set it to say 75 it does not seem to hold that temp. I have no codes on the C68 it just seems to always been that way. I was wondering if they were like that from new.
Old Apr 14, 2015 | 09:15 PM
HAD2HAV2's Avatar
HAD2HAV2
Pull the Blower Control Module out (in the engine bay). Shine a flash light into the hole and look toward the firewall. Get a helper to adjust the Temperature up and down. You be able to see the door move that allows cold and hot air into the cabin. You will also see the Heater core. Let us know what you see at 60, 75, and 90.
Old Apr 14, 2015 | 11:20 PM
Cliff Harris's Avatar
Cliff Harris
The C68 system was completely redesigned in 1990, so it's important to know what year your car is.
Is your car a '96? If so, see this thread:
https://www.corvetteforum.com/forums...l-problem.html
For reference, when looking through the evaporator housing opening the temperature blend door should look like this in the 60° position:
It should look like this in the 90° position:
Old Apr 15, 2015 | 05:01 PM
eutu1984's Avatar
eutu1984
OK the blend door is working it fully blocks the heater core when set at 60 and fully goes the other-way at 90, it goes to the same position at 70 as it is at 90.
Old Apr 15, 2015 | 06:51 PM
eutu1984's Avatar
eutu1984
My real question is if anyone with the C68 system does yours stay at say 75 when you set it there or does it do the same as mine.
Old Apr 15, 2015 | 08:26 PM
HAD2HAV2's Avatar
HAD2HAV2
At 75 my door is close to 50/50 open/closed.
Old Apr 15, 2015 | 08:46 PM
eutu1984's Avatar
eutu1984
Thank You, does your C68 keep your temp inside the car at around 75.
Old Apr 15, 2015 | 09:33 PM
HAD2HAV2's Avatar
HAD2HAV2
The only time of year I would say the interior is warmer than 75 is in July and August. I have to lower the temp. to 68 - 70 to feel comfortable.
My C68 is a 88. I just had the AC/Heater programmer repaired by BATEE.COM. My Blend door would get stuck in the 60 -65 setting and when last November came along I had no heat.
Old Apr 16, 2015 | 12:06 AM
Cliff Harris
That sounds like a problem in the HVAC programmer (located above the gas pedal, bolted to a bracket on the firewall with a 7mm screw). The motor direction resistors get very hot and can either break or cause the solder to go bad. Take the HVAC programmer out and check out the resistors.
The resistors in question are in the lower left corner of the PC board in this picture. You can see that the PC board is discolored from the heat:
Old Apr 16, 2015 | 04:49 AM
eutu1984's Avatar
eutu1984
I had the programmer out when I first got the car to fix a vacuum leak, my controller is different than the one in your pic Chris, it does not have the two big resisters in the lower left.
Old Apr 16, 2015 | 05:07 AM
eutu1984's Avatar
eutu1984
the inside of my programmer looks like this one
http://galleryplus.ebayimg.com/ws/we..._1/500x500.jpg
Old Apr 16, 2015 | 01:36 PM
Robert Perkins's Avatar
Robert Perkins
That is a 1990 or newer unit. You did not say what year your car is.
Old Apr 16, 2015 | 03:04 PM
eutu1984's Avatar
eutu1984
Sorry it is a 90.
Old Apr 16, 2015 | 03:13 PM
Robert Perkins
Sorry it is a 90.
I also have a 1990 and it works much the same way as yours. I set to max temp either hot or cold and adjust as I get confortable. This system is not going to work like the new car rember it is 25 years old with probably 30 year old technology.
Old Apr 16, 2015 | 03:34 PM
eutu1984's Avatar
eutu1984
I understand its age related Rob but I am going to try and trouble shoot it to see if I can get it to work correctly. I am looking through the FSM and am going to try and check all the perimeters to see if it is anything else before I mess with the programmer. Right now I am busy with the front spring. https://www.corvetteforum.com/forums...af-spring.html
Old Apr 17, 2015 | 01:35 AM
Cliff Harris
The whole point of the automatic digital system is that you don't have to do that. Set it to the temperature you want and the system will do what it takes to get there.
To C68
