Gas in the sump??
On a '87 L98, assuming you had a torn fuel pump regulator diaphragm and gas was being sucked up through the diaphragm into the plenum chamber, ..would that gas find its way into the sump? If so, by what route?
I'm thinking the gas would run down the runners into the intake and to the back of the valves, but with no further access to contaminate the sump oil.
Am I wrong?
Cheers,
Steve
Am I wrong?
Cheers,
Steve
Am I wrong?
Cheers,
Steve
; also a leaking injector(s) can be the culprit
