EGR valve
Old Apr 17, 2015 | 02:03 PM
Grenkepr's Avatar
Grenkepr
Default EGR valve
My 88 is throwing a code 32 which is the egr. Are there any ramifications to driving it for short periods this way. Hate the thought of changing it out now that summer is here......thanks !
Old Apr 17, 2015 | 02:11 PM
don hall's Avatar
don hall
May help (?): http://tech.corvettecentral.com/2012...egr-diagnosis/
Old Apr 17, 2015 | 02:51 PM
tbirdsps's Avatar
tbirdsps
It won't hurt a darn thing to run it inoperative. I ran mine for 2 years with a code 32. However, with the service engine soon light on you may not notice other codes popping up because the light is on a lot.
Old Apr 17, 2015 | 03:03 PM
Grenkepr's Avatar
Grenkepr
Originally Posted by seabright
Great article.Thanks
Old Apr 17, 2015 | 03:16 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
32 relates to the exhaust temp switch, so messing with the valve, may not be necessary.
From my 86 manual
http://members.shaw.ca/corvette86/Code%2032.pdf
Old Apr 17, 2015 | 06:16 PM
Grenkepr's Avatar
Grenkepr
From my 86 manual
This is wh
at I wanted to hear. Thanks
Old Apr 18, 2015 | 01:39 AM
Cliff Harris's Avatar
Cliff Harris
You get an error code 32 because the EGR SYSTEM is not working. The ECM turns on the EGR solenoid, which furnishes vacuum to the EGR valve. The EGR valve opens and the hot exhaust gasses flowing through the EGR tube cause the EGR temperature switch to turn on and let the ECM know that all is well. It's easy to replace the temperature switch, but the problem might be elsewhere.
In my case the EGR solenoid went bad and was not opening the EGR valve, which froze in the closed position. I bought a new EGR valve from AutoZone, but it was bad right out of the box. Best to test it before installing it. I ended up buying an AC Delco EGR valve from the Chevy dealer. It cost more, but at least it worked.
Old Apr 18, 2015 | 06:29 AM
kenmohr's Avatar
kenmohr
Yep Me too almost exact.
Old Apr 18, 2015 | 09:50 AM
QCVette's Avatar
QCVette
Yep Me too.
On my '88 it was just the egr valve. I also got one from Advance auto and it was bad. The second one was bad too, plus it was the wrong one in the right box. Both of them would not open when a vacuum was applied. I got a AC Delco from Rock Auto and it was good.
In my case the code 32 only showed up after about 10 miles on highway cruise. In town and other conditions it did not set the code.
There were also some threads on this forum that described a way to "trick" the system by a jumper connection to the temperature switch. I did not want to do the EGR repair right away and so I tried the "trick". I could not get it to work on my car.
Good luck.
Old Apr 18, 2015 | 10:33 PM
HAD2HAV2's Avatar
HAD2HAV2
I bought a new EGR from O’Reillys 2 years ago and have added about 7,000 miles on my 88. Ok so far. Of course I replaced my EGR when I removed the intake and heads. After 120,000 miles the original GM EGR still functioned.
To EGR valve
