MSD questions
Old Apr 18, 2015 | 01:11 PM
dgantt's Avatar
dgantt
Default MSD questions
i have a 1990 it currently has the stock HEI system on it, I want to change the entire system to a MSD set up. Im having a hard time finding a MSD distributor. Im going to use the 6AL set up, new 8.5 plug wires and coil. Any one have any experience with this set up or part numbers. Thanks for any help.
Old Apr 18, 2015 | 02:44 PM
Crash594's Avatar
Crash594
Just use the factory dist. And upgrade the internal parts with the msd replacements.
Old Apr 18, 2015 | 03:19 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Why?
Old Apr 18, 2015 | 05:18 PM
dgantt's Avatar
dgantt
I would like to freshen up the ignion system because its 27 years old and thought MSD would be a good choice. Also I have a fair amount of upgrades to the car and plan on superchrging it and thought it would add some performance.
Originally Posted by 69427
Why?
Old Apr 18, 2015 | 08:01 PM
DanielRicany's Avatar
DanielRicany
Don't get a 6AL, get a 6AL-2.
Old Apr 18, 2015 | 08:31 PM
dgantt's Avatar
dgantt
Why the 6AL2 over the 6Al?
Old Apr 18, 2015 | 09:21 PM
69427's Avatar
69427
I'm running a turbo 355 in my '84 with the stock (31 year old) Delco ignition. Runs fine and smooth under boost.
It's your money, but I'd be real curious what you're actually going to improve for what you'll be spending.
Old Apr 18, 2015 | 11:51 PM
HAD2HAV2's Avatar
HAD2HAV2
I faced the same decision when I did a heads / intake rebuild. I went with stock distributor parts with up grated spark plug wires. I went with a different spark plug, an E3. Great response couldn’t be happier.
Old Apr 19, 2015 | 12:50 AM
aklim's Avatar
aklim
What exactly are you going to put on? If you go the route some have and get the Holley Stealth Ram, it mandates you find a new distributor. In my case, I have the 8366 distributor that gets spark from a divorced coil 8223 mounted in the engine compartment. Will they add performance? Sure, if your current system is shot. Otherwise, probably not. I am running 410 at the wheels and that is what I am using. No multiple spark.
Old Apr 19, 2015 | 12:53 AM
383vett's Avatar
383vett
I'm running my stock 31 year old distributor on my 84 bracket car with a MSD 6AL2. Good for low 10's@133, 6800 rpm.
Old Apr 19, 2015 | 07:37 AM
aklim's Avatar
aklim
Does the MSD 6AL2 really help much?
Old Apr 19, 2015 | 09:54 AM
DanielRicany
It has a 2 step. That's the only difference compared to the 6AL. My 2 step launches very consistent on the street. And they are damn good launches too.
Old Apr 19, 2015 | 03:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sounds like a good way to spend a LOT of money on no power increase and a possible decrease in reliability....IME.
Old Apr 19, 2015 | 04:00 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No. Not for meaningful HP or tq.
Old Apr 19, 2015 | 06:35 PM
dgantt's Avatar
dgantt
I have the edelbrock high flow runners and intake along with a ported plenum so stock size is not an issue although a smaller distributor would be nice. Thanks for all comments but Im guessing MSD does not make a direct drop on replacement?
Old Apr 20, 2015 | 12:06 AM
aklim's Avatar
aklim
No, not that I have seen. Still, if you want to make it easier to get a cap and rotor, I'd change to a divorced coil. Otherwise, I'd have a spare one standing by and be fine.
To MSD questions
