Electrical Problems
Old Apr 19, 2015 | 11:34 PM
1993BlackVette's Avatar
1993BlackVette
Default Electrical Problems
Hey everyone. My car is having some problems with the alarm system. It was going of at all hours of the night until I discovered in the manual how to disable the alarm by locking the doors manually. It worked for a while but now when I do that, the interior lights stay on. For now I'll just have to unplug the battery but I'd like to get it fixed ASAP, as I'm surrounded by inbred *******s. It's also worth noting the passenger side door lock sticks, I have to hit the switch several times to get it to engage. Whoever had it before tore up the interior trying to install speakers. I don't even want to know what they planed on doing in the doors, but they manged to **** it up pretty good. I have a feeling they caused the alarm problem to. Any help is appreciated guys.
Old Apr 20, 2015 | 12:07 AM
Hooked on Vettes's Avatar
Hooked on Vettes
You can verify the door ajar switches work by turning the ignition on and opening one door at a time. The door ajar indicator should come on in the driver information center. Close the door and the indicator should go out.
The switches are located on the back of each door. Some people say they can be adjusted by carefully pulling the center portion of the plunger out. When you shut the door it will self adjust.
As for the interior lights staying on, insert the door key in the key cylinder and make sure when you remove the key the lock cylinder is vertical when you pull the key out.
The factory alarm only monitors the two door switches on the back side of the door and the hatch switch.
When the alarm goes off, if all the interior lights are on one of the door switches caused the alarm to trigger. If only the cargo lights are on the rear hatch switch cause the alarm to trigger.
