TPIS intake question for 85
Old Apr 19, 2015 | 07:25 PM
nickpe's Avatar
nickpe
Default TPIS intake question for 85
hello to all,
my 85 has the cold start injector.
I'm installing the TPIS Mini Ram
What do I do with the cold start injector.
Do I just eliminate it... Also is there a bracket for the throttle cables
thanks for the help,
nick
Old Apr 19, 2015 | 08:02 PM
C409's Avatar
C409
........ Leave the cold start stuff with the old Tuned Port Intake Manifold ... depending on which ECM you plan on using , your car might be tough to start in really cold weather , but unless you're modding your daily driver , I wouldn't worry about it ........ TPIS sells a throttle cable bracket for about $35 ... you will need it ...........
Old Apr 19, 2015 | 08:16 PM
nickpe's Avatar
nickpe
thanks for taking time to help me
Nick
Old Apr 19, 2015 | 08:21 PM
nickpe's Avatar
nickpe
Nick
I was going to use my 85 ecm, its chiped for the 510 lift cam 10" converter, ported heads, headers.
couldn't afford the intake till now.
Old Apr 19, 2015 | 09:00 PM
DanielRicany's Avatar
DanielRicany
I didn't have to purchase a separate bracket for my Miniram.
Old Apr 19, 2015 | 10:54 PM
blackozvet's Avatar
blackozvet
with the 85 computer and no cold start injector, for a cold start, just push the throttle down about a 1/4, then crank. It should fire up pretty quick.
When you push the accelerator past idle position the ecm will enrich the injectors.
Works for me with my single plane.
Old Apr 20, 2015 | 01:19 AM
JackDidley's Avatar
JackDidley
You can work around the csi. Just adjust the start process when it is cold. It would help if you got it tuned for the Mini. Mine like some extra spark advance.
Old Apr 20, 2015 | 10:43 AM
vader86's Avatar
vader86
Have your tuner spend some extra time getting the initial startup right when the chip gets done. Its one of the main issues I've struggled with on my modified engine.
Old Apr 20, 2015 | 08:02 PM
nickpe's Avatar
nickpe
Hello Vader,
If I may ask, who do you recommend to tune the 85 chip
Old Apr 20, 2015 | 08:19 PM
DanielRicany
Hello Vader,
There is barely anyone left who will tune an '85. I had to do mine by myself because the people who were tuning mine were not tuning it right.
I can tune your chip to the best of my ability over email. I won't charge you a penny.
It will require that you use an AFR gauge though in order to make it run as desired in certain aspects of the tune. Just message me your email address and we'll talk there.
Old Apr 21, 2015 | 05:40 AM
WW7's Avatar
WW7
You could also get in touch with "Mr ******" , I'm not certain but he may be able to help...He has posts on here often, and he offered to help me if I got a miniram.....WW
To TPIS intake question for 85
