Weird transmission issue?
Old Apr 21, 2015 | 08:54 AM
ClaudioC4's Avatar
ClaudioC4
Default Weird transmission issue?
I have an 85 with a 4+3. When reversed out of my garage, the reverse would not dis-engage. If I put the car in first gear it would battle the reverse and it was like a tug of war. If I pit it in neutral and released the clutch the car would buck and stall. Eventually as I popped it in and out of reverse it released. Am I headed for a catastrophic failure.
PS. I actually love the 4+3 and up to this point it has been great.
Old Apr 21, 2015 | 08:59 AM
antfarmer2's Avatar
antfarmer2
Been sitting for awhile? Clutch might have rusted stuck
Old Apr 21, 2015 | 09:42 AM
ClaudioC4's Avatar
ClaudioC4
It had only been sitting for a day, but my throw out bearing has been squealing when the clutch is not engaged, maybe it is sticking?
Old Apr 21, 2015 | 09:53 AM
WVZR-1's Avatar
WVZR-1
I would first check the shift rods and the shifter adjustment. There's a procedure for setting the adjustment in neutral. Do you have the FSM?
You might consider adjustment of the park-lock cable also when doing the shifter alignment.
Old Apr 21, 2015 | 10:08 AM
ClaudioC4's Avatar
ClaudioC4
Just a Haynes manual no FSM yet.
Old Apr 21, 2015 | 10:33 AM
WVZR-1's Avatar
WVZR-1
Here's an interesting thread for you maybe:
https://www.corvetteforum.com/forums...alignment.html
Old Apr 21, 2015 | 10:49 AM
ClaudioC4's Avatar
ClaudioC4
Thanks, I think that may help, the car is on stands right now as I replace the shocks so I will have a look underneath.
Old Apr 21, 2015 | 04:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
x2 on checking shift rods
Old Apr 22, 2015 | 10:44 AM
Mtn Billy's Avatar
Mtn Billy
I had the clutch master cylinder go out and it was a bear to get in or out of gear. Check you master cylinder fluid level. It could also be the slave cylinder.
Old Apr 22, 2015 | 10:55 AM
WVZR-1's Avatar
WVZR-1
This and the confirmation of shifter rod adjustment should be done at the same time. Car's on stands so it would be the prime time to confirm hydraulic leaks as well as confirm the shifter rod adjustment.
Use "clutch hydraulic fluid" GM # 12345347 or equivalent for the clutch system hydraulics.
Old Apr 23, 2015 | 02:06 PM
ClaudioC4's Avatar
ClaudioC4
Should a dealer cary this fluid? Would I benefit from just changing the fluid?
Old Apr 23, 2015 | 02:21 PM
WVZR-1's Avatar
WVZR-1
A dealer should have and to avoid the risk of breaking something you could remove fluid from the master with a baster and refill with as much as possible of fresh, repeat a few times on a frequent basis until you've got a reasonably fresh fill.
What I mean by breaking something is perhaps the bleeder screw was frozen in the slave, I wouldn't force the issue to the point where you could twist off the bleeder.
To Weird transmission issue?
