1995 wheel axle nut torque spec
Old Apr 25, 2015 | 09:36 AM
Christi@n's Avatar
Christi@n
Default 1995 wheel axle nut torque spec
Hi all
Can anyone from FSM tell me torque spec for spindle nut?
36mm hex nut rear axle, taken a look around somewhere says 164, some other 174 or even 200 lb /ft
Old Apr 25, 2015 | 09:53 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by Christi@n
Hi all
I've never seen the C4 FSM updated or a TSB related that increased the spec from 164 lbft. I do believe that there was a TSB for later generation (C6) but I've certainly not looked.
I haven't looked either for a C4 spec change for many years.
Old Apr 25, 2015 | 10:00 AM
don hall's Avatar
don hall
164 confirmed per this link:
http://www.speedwayautoparts.com/Torque%20Specs.pdf
Old Apr 25, 2015 | 11:17 AM
aDigitalPhantom's Avatar
aDigitalPhantom
From what I understand there are a number of s10s that use the same bearing on the front.
The torque spec for the S10 is 181 ft/lbs
The torque spec for the C4 is 164 ft/lbs
Old Apr 25, 2015 | 12:13 PM
WVZR-1's Avatar
WVZR-1
I've seen higher numbers for the bearing nut when used on "steering axles" and that bearing was used on many FWD cars. None of the applications I believe are newer than '90 and even some/most of the after-market mention the 164 number, others mention the number for the specific application.
Assembly is a little different on the applications where it's installed on a steering axle.
Old Apr 25, 2015 | 01:36 PM
Christi@n's Avatar
Christi@n
Thank.you all.
At the moment i've fixed it at 164.
Seems to work fine
Any other upgrade....i'm here
Old Apr 25, 2015 | 03:12 PM
aDigitalPhantom
You missed the point. IF it is the SAME bearing the fact other applications use a higher torque spec SHOULD mean that the higher torque spec wont hurt it on the C4.
Old Apr 25, 2015 | 06:41 PM
WVZR-1's Avatar
WVZR-1
I didn't miss anything, the FWD "steering axles" I'm quite sure didn't have a thrust washer like the C4 rear axle applications have.
Actually I believe you can only find the interchange of the hub/bearing in after-market applications where I believe the vendor assumes the liability for the hub/bearing to be an acceptable replacement.
Old Apr 25, 2015 | 07:53 PM
Christi@n's Avatar
Christi@n
There are many brand of wheel hub MOOG DELCO RAYBESTOS, from 30$ to 200 $ and more, are they the same wuality and is the difference in just about the brand? Or is the a difference in quality too?
Old Apr 25, 2015 | 08:30 PM
WVZR-1's Avatar
WVZR-1
That can certainly and is debated often. It's an "unknown" and a gamble for sure. The tooling for even the highest quality production suppliers is likely worn out and I doubt any of them continue to provide product that's within OE specs or for that matter their own specs of just a few years ago.
I believe that all of them likely just provide a product that can be "priced" to where it's thought to be competitive. There are likely exceptions but will the majority pay? Probably not.
Your location certainly doesn't give you much of a shopping choice, I'm sure it's a difficult decision.
The largest supplier of hub bearings to the OE in the US NTN/BCA doesn't even offer the bearing discussed here. Likely the tooling wore out and it's easier to just "quit" and focus on long run OE product.
Old Apr 26, 2015 | 09:59 AM
aDigitalPhantom
There's that talk down to others attitude again...
Well as your so sure that going over 164 ft/lbs is harmful IF I remember to I will tell you how many thousands of miles my replacement bearing lasted at 190 when it fails.
Old Apr 26, 2015 | 11:21 AM
WW7's Avatar
WW7
From what I have seen on this and other forums, Timken and SKF are the 2 most recommended bearings to use on our cars..Both are around $150.00, but you can't go wrong with either one...WW
Old Jun 28, 2015 | 09:17 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Hi all
per video of install, 160
video
Old Jun 28, 2015 | 09:36 PM
Mishawaka's Avatar
Mishawaka
Just replaced my rear drivers side today. I torqued it to 150lbs then turned far enough to get the cotter pin in. I figured that probably put it close to where it needed to be.
Old Jun 29, 2015 | 05:58 AM
Christi@n's Avatar
Christi@n
I definetely torque them at 164 ft/lb
I've mailed at corvette central to ask them this info, they said the Torque for my year (1995) according to FSM is 164 ft/lb
Replaced rear bearing with NATIONAL 513020, very good part, new teflon washers, greased well inside spindles washer ecc...
This way fixed very well rear clicking sound, thought culprit was grease lack inside
To 1995 wheel axle nut torque spec
