'93 automatic trans shift points?
Old Apr 26, 2015 | 09:17 PM
Ozzstar's Avatar
Ozzstar
Default '93 automatic trans shift points?
1993 LT1, 4L60 auto transmission
What are the normal range MPH shift points for 1-2, 2-3 and 3-4? Under normal load? I remember reading this somewhere and can't find it in the service manual.
I adjusted the TV cable and the transmission shifts under very LIGHT load 1-2 at 10 mph 2-3 at 22 mph and 3-4 43mph and the torque converter is locking up and RPM's dropping to "normal", at highway speed while cruising under light throttle.
thanks - Ozz
Also, anyone know where the thread on the 4l60 trans governor might be hiding? I am thinking of changing the fluid and filter and while i'm under the car check the governor for any signs of trouble.
Old Apr 27, 2015 | 03:44 PM
don hall's Avatar
don hall
Might help (?): http://sethirdgen.org/tvcable.htm
Re trans governor: http://www.camaroz28.com/forums/adva...estions-98918/
Old Apr 28, 2015 | 10:50 PM
Ozzstar's Avatar
Ozzstar
Originally Posted by seabright
Thanks Seabright
To '93 automatic trans shift points?
