C4 Electrical experts needed here!
Old Apr 28, 2015 | 03:47 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default C4 Electrical experts needed here!
Does anyone know what the is the range of the temp sender for a 93? Am I correct in assuming that it is a resistance device? As it gets hot the resistance goes up or down. Please enlighten me. thanks!
Old Apr 28, 2015 | 05:02 PM
Robert Perkins's Avatar
Robert Perkins
The hotter it get the lower the resistance. 55 ohms 280 degrees and 1400 ohms 100 degrees give or take a few. The rule of thumb is open (high resistance off scale high. Short ( no resistance is off scale low.
Old Apr 28, 2015 | 10:10 PM
Ozzstar's Avatar
Ozzstar
The coolant temp sensor is called a thermistor, look that up and you will find your answer on how it works. - Ozz
Old Apr 29, 2015 | 12:42 AM
Cliff Harris's Avatar
Cliff Harris
There are several temperature/resistance charts in various places in the FSM. Here's one:
Old Apr 29, 2015 | 02:43 AM
WVZR-1's Avatar
WVZR-1
The analog gage in the later C4's I believe 55 OHM is considered HOT and something 1400 OHM is considered COLD - it varies widely between the extremes. Some aftermarket replacements mention different "reference" specifications.
You DO NOT rely on the analog gage in a later C4.
Old Apr 29, 2015 | 11:15 AM
87bob's Avatar
87bob
Thanks Guys. Does anyone know anything about the sender in a 2006 3/4 ton 6.0L truck engine. For example are they both analog? what is the range values on the 2006 engine.
Old Apr 29, 2015 | 01:06 PM
WVZR-1's Avatar
WVZR-1
You don't need to be concerned about the '06 other than the CTS for the "RUN" function for the PCM/ECM. For the gage you're only concerned about the COLD - HOT values of a sender as I mentioned in your other thread. You've only got a DK GRN wire to the gage sender I believe even though some of the later LT engines used a 2 terminal sender. Is that correct?
Old Apr 29, 2015 | 02:46 PM
87bob's Avatar
87bob
Yes the 93 has a two wire coolant sensor. One is Black and is a ground the other is yellow and goes to the ECM. Hmm, the pig tail of the 2006 engine has a yellow and black wire coming out of itIf I could find out the values for the 2006 engine I may be able to change out the wire terminal end (weather pack) and use the 2006 sensor to feed the 93 ECM. That would be awesome!
Old Apr 29, 2015 | 07:16 PM
87bob's Avatar
87bob
According to what I have found the sensor in the 2006 truck motor reads the same as in the 93 Vette motor the pig tail is different and will need to be changed but the sensor should allow the gauge to work properly. here are the values for the truck sensor:
Temperature
Resistance
50° F (10° C) 5670 Ω
68° F (20° C) 3520 Ω
86° F (30° C) 2238 Ω
104° F (40° C) 1459 Ω
122° F (50° C) 973 Ω
140° F (60° C) 667 Ω
158° F (70° C) 467 Ω
176° F (80° C) 332 Ω
194° F (90° C) 241 Ω
212° F (100° C) 177 Ω
Old Apr 29, 2015 | 08:33 PM
WVZR-1's Avatar
WVZR-1
I thought you wanted to discuss the TEMP GAGE ON THE CLUSTER - you're talking now about the CTS for the ECM. Which is it that you want to discuss?
I was only mentioning that it's possible that the LT had a two terminal sender for the gage BUT that it functions also as a single pin sender if you were wondering the why I pointed you to a single blade sender.
You need to accomplish the RUN functions using something other than the LT ECM.
Temperature
Resistance
Those numbers I doubt are for a TEMP GAGE SENDER - I won't dispute it but where did you arrive at those numbers. What part number did you use? Those look like CTS>
Old Apr 30, 2015 | 01:12 AM
Cliff Harris
As I mentioned in my post, the numbers are the same for ALL the coolant temperature sensors (and the MAT sensor too). The physics doesn't change just because a particular sensor has a different function.
The only exception is the CTS that the ECM uses. It uses a two wire CTS and does some electronic and software magic to make it more accurate.
Old Apr 30, 2015 | 03:06 AM
WVZR-1's Avatar
WVZR-1
I'm quite familiar with characteristic curves for thermistors/temp sensors/senders etc. I have quite accurate sensors in a couple weather stations. There's many curves and the senders used for non-linear gages are very random with generally a low/cold value and high/hot resistance values with very large tolerances. Those that have "alarms" or "warning" lights included aren't similar at all.
I believe a gage check of an early digital cluster is done 1600/LO to 75/261* with a +/- of 6*. There are specific values for various TEMPS mentioned but the +/- 6 still applies.
OP - I'd do this if it were my conversion I think or it's maybe my first thoughts. I'd buy an M12 X 1.5 single pin sender intentioned for a gage with advertised specs of something 55 - 1400 or close. Once I had the car running as I wanted I'd use a scanner to confirm the TEMP indication on my analog gage vs. the CTS (for the PCM/ECM) and "drive on".
To C4 Electrical experts needed here!
