Time to Change Plugs
Old Aug 14, 2002 | 11:32 AM
CAJUN C4's Avatar
CAJUN C4
Default Time to Change Plugs
Thinking of using reg. old A/C's with the arm cut back trick...Heard it's good for about 10 H.P.?
Any better suggestions.
Old Aug 14, 2002 | 02:52 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Time to Change Plugs (CAJUN C4)
That's what I'm running and the trap speed tells the story, 8-10hp gain.
Old Aug 14, 2002 | 02:56 PM
93TorchRedC4's Avatar
93TorchRedC4
Default Re: Time to Change Plugs (65Z01)
:eek: No kidding, huh? That'll be my next mod! Thanks! :seeya
Old Aug 14, 2002 | 03:08 PM
STL94LT1's Avatar
STL94LT1
What is the cut back trick ?
Old Aug 14, 2002 | 03:19 PM
james holley's Avatar
james holley
Do the plugs last as long? Somebody 'splain exactly how it's done 'cause if it's good for more hp, I'm doin' it next! :reddevil
Old Aug 14, 2002 | 03:20 PM
CAJUN C4's Avatar
CAJUN C4
Default Re: Time to Change Plugs (STL94LT1)
You grind / cut the electrode arm back till it meets the inner edge of the center electrode.Unshrouds the spark.
Old Aug 14, 2002 | 03:23 PM
CAJUN C4's Avatar
CAJUN C4
I don't know it affects longevity ? Anyone know ?
Old Aug 14, 2002 | 04:14 PM
Caboboy's Avatar
Caboboy
http://www.gmtips.com/3rd-degree/dox...tion/spark.htm
see if this link works. i wasn't too sure about exactly how to do this mod either. if the link doesn't work, type "spark plug electrode modification" into your search. see, i am more than just another pretty face! :lol:
Old Aug 14, 2002 | 05:22 PM
65Z01's Avatar
65Z01
I had read about this trick in TPIS "Insider Hints" and in Dave Emanuel's book on SBCs.
Since then I've been running them in both the IROC and the Vette.
There's a sketch on my site.
Old Aug 14, 2002 | 08:09 PM
Lone Ranger's Avatar
Lone Ranger
I'm not saying it doesn't work, but I wonder why no plug company hasn't started making out of the box cut back plugs like this and charging a premium price? Isn't this sort of the theory (expose more spark kernel to the air/fuel charge) behind the Bosch +4's that many claim to be gimmick plugs?
Old Aug 15, 2002 | 03:02 PM
cash's90's Avatar
cash's90
Default Re: Time to Change Plugs (Lone Ranger)
My son in law just purchased some Autolite Racing Plugs to replace the V-Power NGKs in his '67 Nova race car. His Nova is equipped with a high performance 350 small block. The NGKs were not available so the parts store suggested the Autolites as replacements. I had just discussed this forum with him and we talked about modifying his new plugs.
When we opened the box, without reading the small print on the box, we were surprised to find they had cut back ground electrodes.
Autolite now sells these as Racing plugs. His Autolite Racing plugs are part number AR134.
Old Aug 15, 2002 | 09:52 PM
james holley
Default Re: Time to Change Plugs (cash's90)
Can someone post pictures of what the finished product will look like? thanks
Old Aug 15, 2002 | 11:41 PM
blk_c4's Avatar
blk_c4
Default Re: Time to Change Plugs (james holley)
Look at caboboy's link above. Interesting thread and wonder if it works on an 84 crossfire?
Old Aug 19, 2002 | 10:27 AM
CAJUN C4's Avatar
CAJUN C4
WOW!!!! I Can't even believe what a difference....Seriously, I can Really feel a set of the pance difference with this Modification....Un-Real...Took me about a half hour with my Dremel. You really have to do this..... 8-10 free H.P.
Dennis
Old Aug 19, 2002 | 10:59 AM
ZZZASY's Avatar
ZZZASY
Is cutting the plugs something you can do on later model cars (eg. '96) are only 80 model cars?
Curtis
96 LT4
Old Aug 19, 2002 | 11:21 AM
CAJUN C4's Avatar
CAJUN C4
Default Re: Time to Change Plugs (ZZZASY)
Curtis...It will work on any model.
Old Aug 19, 2002 | 01:08 PM
Lone Ranger
What are the best plugs to cut back for an LT1, regular copper AC's? Does a hand file (metal file) work okay to cut them back? And finally, should the gap be left stock spec or closed up some if one has a stock coil?
To Time to Change Plugs
Old Aug 19, 2002 | 01:24 PM
CAJUN C4's Avatar
CAJUN C4
See The Poat above from "Caboboy"
Use A/C 's Copper or otherwise, I used my Dremel bent out the electrode a bit, cut to where I wanted and Gapped .050" (.045" std) File to de-bur. you don't want any sharp edges etc.
Unbelievable the difference it made.
Old Aug 19, 2002 | 01:30 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
No gimmick...they work!
Old Aug 19, 2002 | 01:37 PM
CAJUN C4's Avatar
CAJUN C4
Default Re: Time to Change Plugs (Hardcorvette)
BTW...Autolite has racing plugs allready cut back.$2.99 each.
The "AR" series.
