accel gen 6 question
Old Aug 14, 2002 | 11:27 PM
tangerine383's Avatar
tangerine383
Default accel gen 6 question
I am running a 383 with trick flow heads,9.2 compression,1000 cfm throttle body,lingenfelter intake with 50 lb. injectors. Yes I do have it running with 50 pounder's. My question is -what is your guy's settings on the TPS % and the amount the throttle blades are open at idle? I cant get my set up to idle down below 1100 rpm's with out shutting down.I have tried setting the blades at 6to 8% and then set the TPS% at 1.9.the best performance I have had is the TPS% at1.9 and then the throttle at3 to 4%.But it still die's at idle.Any help would be greatly appreciated.Oh,timming at idle is 20 degree's and fuel pressure is 45lb's,these are all when the car is warmed up . :crazy:
