Wheels
Old May 11, 2015 | 10:37 AM
spro2395's Avatar
spro2395
Default Wheels
Hi All,
Would I be able with adapters to get this wheel to fit an early C4 (85) ?http://www.oewheelsllc.com/Wheels_3/...T#.VVCvnCjrZ0M
Old May 11, 2015 | 10:46 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Just buy them with the correct offset for the C4. IN 88 they went to the 50's mm, The later C4 was 56mm Not sure about the early C4 38mm? Someone who knows more about this than I will post up I'm sure.
Old May 11, 2015 | 11:27 AM
spro2395's Avatar
spro2395
Unfortunately OE Wheels does not carry anything for early C4s
Old May 11, 2015 | 01:16 PM
rrt898's Avatar
rrt898
If you look around you can find wheels that fit. It took me sometime to find them also. I am not a fan of spacers or adapters. The wheels you are looking at almost look like A-Molds.
Just my experience...Good Luck
Old May 11, 2015 | 06:43 PM
LongBeachC4's Avatar
LongBeachC4
Those are 65mm offset you need 38mm if your going to run 9 1/2" rims. Those are going to be some big spacers.
Old May 12, 2015 | 07:13 AM
spro2395's Avatar
spro2395
I'm actually looking for a second set of wheels to put sticky tires on for autocross. It seems the tire selection in 18" is much better than 17". One of the guys in my club thought he heard that some C5 rears would work in the fornt and back of early C4 s he couldn't remember what year or model though. It would be nice to find a full set of 18x10.5s...
Old May 12, 2015 | 07:20 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Contact HRE wheels; they can make a set of wheels for you in any diameter, any offset, any width you want.
Old May 13, 2015 | 11:47 AM
L98Justin's Avatar
L98Justin
FLEA BAY, has some wheels with correct 84-85 offset
non-z51 cars is 32mm
z51 cars- 38mm
hope this helps
Old May 13, 2015 | 12:06 PM
spro2395's Avatar
spro2395
z51 cars- 38mm
hope this helps
18s ?
Old May 13, 2015 | 12:13 PM
don hall's Avatar
don hall
May help (?): http://www.joby.se/corvette/div/corvette_wheels/
Old May 13, 2015 | 01:10 PM
L98Justin's Avatar
L98Justin
18s ?
i've seen a few, I almost bought some replica c6 18x9.5 zr1's with the correct offset.. hopefully you'll find something you like..
To Wheels
