Headers made my brake line leak help
Old May 14, 2015 | 04:57 PM
sansonic's Avatar
sansonic
Default Headers made my brake line leak help
I put some obx long tube headers in my 86 and failed to heat wrap the brake lines. Now one of them is leaking onto the header causing a puff of smoke when you hit the brakes. I have another wrecked corvette an 87 that has good lines. What I need to know is what size are these stock lines so I can buy the right sized splice kit. I believe the leaking one comes right off the master cylinder.
Thanks guys
Old May 14, 2015 | 05:31 PM
383vett's Avatar
383vett
Did a metal brake line wear through? Was it contacting the header? They don't melt so I'm having trouble visualizing what happened.
Old May 14, 2015 | 06:36 PM
sansonic's Avatar
sansonic
I think it wore through. There was a heat shield Infront of it and I didn't know the header was directly touching the line.
Old May 14, 2015 | 06:39 PM
383vett's Avatar
383vett
Can you use the lines off the 87?
Old May 14, 2015 | 06:51 PM
sansonic's Avatar
sansonic
I can but if I just remove the lines I'd have to remove the line through the entire system and do the same on the 86. Trying to see if this is the easier way
Old May 14, 2015 | 07:01 PM
DanielRicany's Avatar
DanielRicany
Are you able to post a picture of this? I had to bend my brake lines a little to stop them from touching my hooker headers. I also used a piece of paper heat shielding that has adhesive on it to cover the brake lines from getting heat up.
I'm very interested in this. If you could go into more detail on how that happened it would be well appreciated too.
Thanks.
Old May 14, 2015 | 07:30 PM
sansonic's Avatar
sansonic
This was the first pair of headers I've ever installed I guess that's why I missed it being to close to the brake lines.
I thought this heat shield was enough when I installed the headers but I guess not.
Old May 15, 2015 | 07:19 AM
spro2395's Avatar
spro2395
I've been trying to figure out how to deal with heat on my header install as well. Decided to not try starting it yet until I sort things out.
To Headers made my brake line leak help
