Faster idle
Old May 15, 2015 | 11:22 PM
mlm0's Avatar
mlm0
Default Faster idle
Is the only way to get faster idle to change the idle rpm settings in the chip?
I have no vacuum leaks and I have replaced almost all sensors and made proper adjustments and settings, but car just idles to low after warmed up
Other than that, it runs great
Old May 16, 2015 | 02:46 AM
Cliff Harris's Avatar
Cliff Harris
Do a minimum idle adjustment:
https://www.corvetteforum.com/forums...post1570563689
Old May 16, 2015 | 08:16 AM
playsdixie's Avatar
playsdixie
i'd check the timing too
Old May 16, 2015 | 12:29 PM
mlm0's Avatar
mlm0
It has all been done
Old May 16, 2015 | 01:25 PM
8a8mfh's Avatar
8a8mfh
No matter what you do mechanically it will always try to idle at the programmed idle rpm.
You could disconnect the IAC and adjust the throttle stop, but the check engine light will come on and it may or may not stall when putting it in gear, running the a/c, etc.
Old May 16, 2015 | 02:31 PM
mlm0's Avatar
mlm0
That's what I though also. I have new chip with faster idle setting I will install today. Just for my own knowledge, if you have vacuum leak, won't that cause a faster idle and not a slower idle
Old May 16, 2015 | 04:04 PM
8a8mfh's Avatar
8a8mfh
Yes, a vacuum leak usually causes a high idle.
Old May 16, 2015 | 05:20 PM
mlm0's Avatar
mlm0
To Faster idle
