1995 Won't start
Old May 17, 2015 | 03:39 PM
72MiuraSV's Avatar
72MiuraSV
Default 1995 Won't start
Hello, my Corvette will not start, the accessorys come on but than when you crank it nothing happens. The "apply pressure" light comes on but when you push the pedal down the light does not go off so I'm thinking this could be the issue why it will not start. Has anyone else had an issue with this?
Old May 17, 2015 | 04:41 PM
aminnich's Avatar
aminnich
Possibly a VATS issue. Is the security light lit and staying on when you turn the key on?
If so it is VATS. Clean the pellet on the key, wait 3-4 minutes and try again.
Old May 17, 2015 | 04:58 PM
kg4fku's Avatar
kg4fku
Never seen the "Apply Pressure" light. Where is this light?
Old May 17, 2015 | 06:44 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Never heard of that either.
Nothing like that on my '96
Old May 17, 2015 | 07:33 PM
72MiuraSV's Avatar
72MiuraSV
I don't remember the exact wording but in order to start it you have to have your foot on the brake. If you don't, a light on the dash saying something to the effect of "apply pressure" will stay lit and the car won't start. BTW mine is a 6 speed. When I put my foot on the brake the light doesn't go out therefor it doesn't start. I had my chip on the key bypassed because my original keys were stolen. So now there is a chip wired in the ignition instead of on the key. This may have to do with this problem.....
Old May 17, 2015 | 07:40 PM
kg4fku's Avatar
kg4fku
never seen it before. Mine is a 6M as well. Is this light located in the DIC or in the Halo above the gauges? Mine will start regardless of the brake pedal.
I would start with your VATS bypass and make sure it is still working. Does the security light illuminate? Blink or steady?
I would also check the clutch pedal switch to make sure that is working as well. The car will not start unless the clutch is fully depressed.
Do you have an after market alarm system?
Old May 17, 2015 | 11:29 PM
72MiuraSV's Avatar
72MiuraSV
Thanks kg4fku, The light is located in the dash on the right side of the gauges. I'll check my car next time I'm at my garage to say for sure what the light says. Ill also check the security light. My alarm system is stock.
Old May 18, 2015 | 10:30 AM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
Starter interrupt relay is a common problem. Might want to check it.
Old May 20, 2015 | 09:47 AM
kg4fku's Avatar
kg4fku
Did you get this all figured out?
Old May 21, 2015 | 05:36 PM
DGXR's Avatar
DGXR
It's directly above the "something is wrong" light.
Yes please follow up if you have any new info. Thanks
Old May 21, 2015 | 10:16 PM
72MiuraSV's Avatar
72MiuraSV
The Corvette has started The problem was the wires that the locksmith had crimped together and taped up for the vats chip were poking out of the tape and frayed. When he first looked at my car, the locksmith noticed the security light did not go out as mentioned. I had the same locksmith recrimp and retape the wire back up. I was thinking this was the problem and honestly glad it was something so simple. Hopefully this time the wires will stay together. I thought it was crazy that I had this done not much more than a year ago and it was falling apart. In any event I'm looking forward to driving. Thanks everybody!
To 1995 Won't start
