Is This A Decent Optispark ?
Old May 17, 2015 | 11:57 PM
Hary Gahtoe's Avatar
Hary Gahtoe
Default Is This A Decent Optispark ?
http://www.ebay.com/itm/NEW-HEAVY-DUTY-OPTISPARK-OPTI-SPARK-IGNITION-DISTRIBUTOR-5-7L-LT1-BRAND-NEW-/351399247526?fits=Year%3A1992%7CModel%3ACorvette&hash=item51d106fea6&vxp=mtr
There's no reference to the optical pickup but the Brass connections are good
Anybody know about this or comments +/- would be great
Old May 18, 2015 | 12:18 AM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Originally Posted by Hary Gahtoe
http://www.ebay.com/itm/NEW-HEAVY-DU...06fea6&vxp=mtr
Given the choice and the aggravation these are to install I would get a vented model....I am a bit skeptical of the 99 buck price. I have zero experience with this brand. I replaced mine back in September with a GM reman that was made in Mexico.
later, tiny
Old May 18, 2015 | 10:15 AM
dizwiz24's Avatar
dizwiz24
i had bad luck once with a gm acdelco 'remanufactured' optispark where they had replaced bearings and seals but chose to re_use the original mitsubishi optical sensor. In fact they even painted over it with black paint to make it look neW.
This was bought thru gmpartsdirect, who were ****s about returning the defective part they sold me, btw.
i returned it thru a gm dealer and the next acdelco remanufactured appear fine, but its still sitting on my shelf
I got lucky and found a lightly used nos unit. (The kind with the tan epoxy cap)
If yours is the 92 thru 94 unvented kind, you need to add a vent to make it reliable
to answer the op question: i wouldnt trust that pos on ebay.
if you are trying to save money on this part you are gambling with your life. A breakdown on a busy, nighht highway, construction zone with no berm, etc. could cost you your life.
Thats the way i view it.
Old May 18, 2015 | 11:05 AM
Hary Gahtoe
Absolutely; if that's all it takes I'd go for the later model vented.
You can't Just swap only the Optispark unit for a late model by itself
Instead of the price of replacing it with a vented model I'd go for a Coil on plug conversion. It's not worth changing the timing cover, timing chain, timing gear etc,etc.
http://www.noid.org/~muttvette/opti.html
Car has original ignition and no failures. (Yet) My consideration is the optical pickup.
Can someone post a photo of exactly how a later model is vented?
Very possible to modify the early model. A vented line from the unit to a higher location with a small waterproof umbrella style cap would work.
Has anyone successfully bought just a high grade Optical sensor alone ?
Thanks for replies
Old May 18, 2015 | 11:22 AM
Hary Gahtoe
I found a photo of a Petris Optispark.
This is for the early model.
What they've done is cap the venting holes with small plastic hose joints and run a line out to a safe T location
To Is This A Decent Optispark ?
