Transmission oil
I have been researching this a little bit and found a lot of stuff for Super T-10 transmissions.
These following questions are specifically in regard to our particular 4+3 transmissions.
People have said that using GL5 has additives that will corrode the syncros over time and that you should use GL4. Is this true?
People have said that using synthetic gear oil will cause the syncros to slip during shifts and make shifting harder or grind the gears. Is this true?
I am currently using Valvoline 80w90 GL5 synthetic gear oil in mine and I have not noticed any hard shifting or any other problems with the trans.
Thanks.
IMHO, unless there is some documentation that says synthetics or multi-grade oils are proven to be better, stay with the factory recommendations. YEars ago there was a debate going on regarding the use of a synthetic AFT in the OD unit. The consensus at that time was to not use a synthetic fluid. As I recall there were a couple of OD unit failures that were attributed to a synthetic fluid. Dexron III is still widely available as are the filters..
Make sure that you can remove the fill plug on the side of the case before removing the drain plug!!
transmission oils:
https://www.corvetteforum.com/forums...post1563122321
Thanks.
