Manual Trans Fluid
Old Nov 30, 2007 | 11:29 PM
vcrz's Avatar
vcrz
Default Manual Trans Fluid
Has anyone replaced their manual trans fluid with something other than the stock Dexron fluid?
If so, have you notice a significant improvement in cold shifts, like when it is around 30 to 40 degrees outside for the first few shifts?
Mine is very notchy in those temps when cold going into second and third; but when warmed up (within a few minutes) it shifts very smoothly. So I was wondering if something like Redline's MTL would help with the cold shifts.
Old Dec 1, 2007 | 12:48 AM
calemasters's Avatar
calemasters
I am using Mobil 1 synthetic Dexron III Spec H ATF.
The shifts are the same. It never gets cold here.
Redline MTL does not meet the "H" specification for the Tremec T-56.
Old Dec 1, 2007 | 11:01 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I replaced mine with Royal Purple Syncromac.
Old Dec 1, 2007 | 11:08 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Makes a difference
Old Dec 1, 2007 | 11:18 AM
vcrz's Avatar
vcrz
Originally Posted by JFTaylor
Makes a difference
Does it make it better when cold too? I have no problem with it warm, only the first few shift when very cold. . .
Old Dec 2, 2007 | 12:21 AM
ZO6 Fan's Avatar
ZO6 Fan
How many Qts for the MN6 Z51? Thanks
Old Dec 2, 2007 | 01:40 AM
Danny318's Avatar
Danny318
What do you expect, magic fluid that doesnt get thicker when its cold? It doesnt take more than a few minutes to get the trans fluid up to temp.
Old Dec 2, 2007 | 03:49 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Same here.
Just did mine but I'm still on stands yet,Doing Z-06 exhaust mod.
Old Dec 10, 2007 | 08:52 PM
vcrz's Avatar
vcrz
4.2 quarts
Old Dec 10, 2007 | 08:53 PM
vcrz's Avatar
vcrz
What is spec H? Does the bottle say if it the oil within meets this?
Old Dec 10, 2007 | 11:12 PM
calemasters
This specification "H" for DEXRON III, H Revision, Automatic Transmission Fluid is primarily for use in General Motors transmissions. Specification "H" describes the requirements for a minimum-performance of the transmission fluid. This would include operating temperatures, frictional characteristics and service life of the lubricant.
If the ATF meets Spec H, it will state this on the label.
Old Dec 11, 2007 | 10:24 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I wasn't having any problems with my transimission but I also went to Royal Purple Syncromax. It wouldn't say there was a significant improvement but there was some improvement (of course, shifting will likely feel better anytime you put-in fresh fluid). I would recommend Royal Purple...it works well for me.
Old Dec 11, 2007 | 10:29 AM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Do not use MTL in the transmissions, we have used RedLine D4 ATF in the street cars and race cars alike with 0 issues.
Some of the gentlemen at RedLine have told me under severe conditions to mix in less than a quart of MTL to the D4 however to help under extreme temperature conditions.
Old Dec 11, 2007 | 10:59 AM
C6~Missle's Avatar
C6~Missle
I plan on using Redline in my 08.. Any compatability issues with the t6060.. thanks
Old Dec 11, 2007 | 11:01 AM
vcrz's Avatar
vcrz
I contacted Royal Purple and Mobil 1 to get their input directly.
Royal Purple said that they recommend staying with the OEM fluid for warranty reasons, but that their Synchromax as it is an alteration of an ATF with the added performance additives and this would be their recommendation for the Corvette manual transmission, if you wanted an improvement. But that it is not GM approved and could void warranty. (the purple color would be a dead giveaway)
No response from Mobil1 yet.
Old Dec 11, 2007 | 11:06 AM
vcrz's Avatar
vcrz
Have you had your car frozen outside for a while and then driveway when it is stone cold? (below 40 degrees) if so, is the shift to 2nd and 3rd very notchy when cold and the butter smooth when warmed up?
Old Dec 11, 2007 | 11:29 AM
Michrider's Avatar
Michrider
I've used Amsoil ATF, has all the right Dex ratings and works a little better when cold. It will be a little less notchy. Some of it is just the nature of the beast, but synthetic will help.
To Manual Trans Fluid
Old Dec 11, 2007 | 11:55 AM
Miaugi's Avatar
Miaugi
Last year I used Mobile 1 ATF and was satisfied with it but this year I switched to Amsoil ATF, can't say it made a huge difference over the M1 but I'll stay with Amsoil for now.
Old Dec 11, 2007 | 01:20 PM
Buffy's Avatar
Buffy
I'm using Mobil 1 ATF; maybe a little better than the factory fill but not a big difference. It is marked "H Spec" on the bottle.
Royal Purple Synchromax seems to be the favorite among those that have tried it; but technically it doesn't meet the spec and could cause a warranty issue. I think this has more to do with not being willing to pay the testing costs and licensing fee for a product mix that doesn't have a wide application than thinking that it wouldn't qualify, at least in the areas relevant to a manual box.
So I wonder - has anyone tried Dexron VI? And would there be any point to it? It is supposed to have more consistent viscosity, as well as being a better lubricant.
Old Dec 11, 2007 | 02:18 PM
ronsc1985's Avatar
ronsc1985
The warranty issue is a non issue. If you crawled under to the car to put in RP in the first place you can crawl under the car again to change back to GM approved fluid before you take it in for repairs.
My 06 C6 shifting improved greatly when I installed RP Sychromax. Apparently my 08 Z06 doesn't require any as they either improved the transmission, the fluid or the shifter greatly or all incrementally. This transmission shifts really smoothly even when ice cold.
