Manual Trans Fluid
Old Dec 11, 2007 | 02:33 PM
vcrz's Avatar
vcrz
Just an FYI for the discussion, here is what the 2008 manual says for the manual trans fluid:
"Manual Transmission Fluid (GM Part No. U.S. 88861800, in Canada 88861801)"
No other specification is noted. For the auto trans it says:
"DEXRON®-VI Automatic Transmission Fluid"
Old Dec 11, 2007 | 02:37 PM
MYVetteBy25's Avatar
MYVetteBy25
Originally Posted by ronsc1985
The warranty issue is a non issue. If you crawled under to the car to put in RP in the first place you can crawl under the car again to change back to GM approved fluid before you take it in for repairs.
My 06 C6 shifting improved greatly when I installed RP Sychromax. Apparently my 08 Z06 doesn't require any as they either improved the transmission, the fluid or the shifter greatly or all incrementally. This transmission shifts really smoothly even when ice cold.
Yeah but you can't get all of it out and when they see the fluid has some purple tint to it then you're in for it
I also put RP Synchromax in my 06 C6. Shifting became slightly smoother, but the rear-mounted T56 and the longer linkage associated with it is still pretty clunky.
Old Dec 11, 2007 | 03:50 PM
Buffy's Avatar
Buffy
Interesting. And it seems that the '07 manual calls for P/N 88861800, also, though the '05 and '06 manuals call for Dexron III. As far as I know the '05, '06 and '07 all have the same transmission - it was only changed for '08, right?
I also found a GM document referencing P/N 88861800 as "manual transmission fluid" and saying that Dexron III can be used if its not available, but not to use Dexron VI in any manual transmissions or transfer cases.
Possibly P/N 88861800 is just the new Dexron III, mainly due to branding issues and not wanting to have too many "Dexrons" floating around confuseling people.
Old Dec 11, 2007 | 04:29 PM
calemasters's Avatar
calemasters
The GM license agreement with Texaco for Dexron III ran out in 2006 and GM did not renew, so now almost anyone can use the Dexron III name. Buyer beware, not all Dexron III today, is the same specs as Dexron III, spec H was back in 2005, when GM controlled the specs.
Also, Dexron VI ATF should not to used in the Tremec T56.
So, back in 2005, it was Dexron III, spec H, but today it is Manual Transmission Fluid GM P/N 88861800 (Canadian P/N 88861801) for the Tremec 6 speed. I believe GM P/N 88861800 is the same as what Dexron III, spec H was back in 2005.
Old Dec 11, 2007 | 04:38 PM
JJC5's Avatar
JJC5
When the fluid is cold, it viscous; thicker. The problem is when the syncros engage, they don't get up to speed fast enough to sync to the next gear due to the thickness of the fluid. Either double clutch or hold the shifter in the syncro notch longer, then slide it the rest of the way.
Personally, I double clutch until the tranny warms up.
Old Dec 11, 2007 | 04:55 PM
vcrz's Avatar
vcrz
So, you noticed this too? Good, it's not just me then and hopefully for both us it's not a problem, but the nature of the beast.
I have been double clutching it. . .
My thought of going to synthetic is that they are more "fluid" when cold than non synthetic, as noted in my old snow car in which I tested the difference in motor oil.
Regular oil (5W30) 8 degrees F cold start in the morning (first one of the day): Valve tap for about 20 seconds.
Changed the oil (and filter) that day to Mobil 1 Synthetic 5W30
Next morning, also 8 degrees: Valve tap for less than 1 second.
That sold me on Mobil 1 and now all our cars have it.
I thought perhaps the same would be true in trans fluid when it comes to the synchros. While they are both (non synthetic vs synthetic) more viscous, the synthetic would flow better and improve cold shifting by allowing the synchros to do their job faster.
Old Dec 11, 2007 | 05:00 PM
JJC5's Avatar
JJC5
That makes perfect sense. Out of all the different fluids that I've read about here on the forum for transmissions, It seems as though Royal Purple is the way to go. Personally, I'm staying with Dexron. It doesn't get that cold here in CA. so it's not too much of a problem.
Old Dec 11, 2007 | 09:03 PM
ronsc1985's Avatar
ronsc1985
Once you fill it up with regular fluid and drive it abut 1 mile it is so throughly mixed you can't tell what color the fluid was previously. Transmissions are splash lubricated and fluid is flying all over the place.
Old Dec 12, 2007 | 02:01 AM
SpinMonster's Avatar
SpinMonster
When I went to get some to refill what I lost during the clutch swap removing the driveline...The manual said Dex 3 so I went and the tech looked it up. The computer said Dex 3 had been replaced and to see Dex 4. When he looked up dex 4 it said see dex 6. I used dex 6 until upgrading my MZ6 for a level 4 unit. I dont know what Cartek filled it with.
Old Dec 12, 2007 | 08:45 AM
vcrz's Avatar
vcrz
Here is the 88861800 bottle (front and back, I just picked one up this morning):
LINK
I am having it analyzed by Royal Purple (they volunteered) and I'll let you know what they find.
Anyone know what the GM specification 9986252 is?
Old Dec 20, 2007 | 08:42 PM
vcrz's Avatar
vcrz
I had the 88861800 fluid analyzed by Royal Purple and they found that it has almost the exact characteristics of Dexron III and that Max ATF or Synchromax will be great replacements, but Synchromax is their first recommendation.
Old Dec 20, 2007 | 09:41 PM
RICKEY BOBBY's Avatar
RICKEY BOBBY
Has anyone replaced their manual trans fluid with something other than the stock Dexron fluid?
If so, have you notice a significant improvement in cold shifts, like when it is around 30 to 40 degrees outside for the first few shifts?
Mine is very notchy in those temps when cold going into second and third; but when warmed up (within a few minutes) it shifts very smoothly. So I was wondering if something like Redline's MTL would help with the cold shifts.
In may opinion dont us ams oil syncromesh I live up north and my trans shifts notchy for over 20 miles at 40 degrees
Old Dec 21, 2007 | 12:27 PM
  #33
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
I have always used the GM synchromesh fluid and have had great luck with it and I can/could tell the difference all stiff changes are gone and is very smooth.
Old Dec 21, 2007 | 09:31 PM
  #34
Adam 17x's Avatar
Adam 17x
I switched to Mobil 1 synthetic ATF in my 05 MN6 at the beginning of the summer and firmly believe that the shifting is even more notchy than with the factory fluid. I notice this when the car is hot or cold. I have 4 quarts of synchomax sitting on my work bench next to my car under its winter cover.
Old Feb 23, 2008 | 01:58 PM
  #35
SnowyATX's Avatar
SnowyATX
Is there any new data out there as to exactly what 88861800 fluid is (i.e. Dexron-III yada, yada? More specifically, how does one know whether any of the non-GM fluids are perfectly fine for use in the '08 tranny?
Old Feb 23, 2008 | 03:04 PM
  #36
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Been using AMSOIL ATF, a fluid suitable for Dexron III specifications in my 02 Z06 for years and in my 06 CTS-V since last year. Works well in both.
Another suggestion that I may try in my Z06 this season is the AMSOIL Torque-Drive Synthetic Transmission Fluid. This is also a Dexron III fluid, but has a little higher viscosity than the AMSOIL ATF and I feel it may work a little better on the track.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 23, 2008 | 09:25 PM
  #37
saber's Avatar
saber
Mobile1 - smoother shifting
Old Feb 27, 2008 | 06:22 PM
  #38
Bscott1's Avatar
Bscott1
Cruising
I put Royal Purple Syncromac in mine and it improved the shifting, still the car does not like to shift smoothly until the tranny warms up.
