5.13 GEARS
Aug 15, 2002 | 10:44 PM
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
5.13 GEARS
Does anyone know who makes a 5.13 gear set for our Dana 44s??????
Aug 15, 2002 | 11:12 PM
Re: 5.13 GEARS (mackeyred96)
_5.13?_ The highest I've seen is 4.09...what, you wanna max out in 6th gear at 70 mph? :jester
Aug 15, 2002 | 11:19 PM
Re: 5.13 GEARS (RocketSled)
TPIS has it for the Dana 44. part no. is 800-358 5.13 41-8 $363.50
Aug 15, 2002 | 11:21 PM
If the bolt pattern and the spline count are the same Jeeps with Dana 44 rearends came with 4:27,4:56,4:88,and 5:38.ratios. Hope that helps :)
Aug 15, 2002 | 11:42 PM
5.13??? damn Mackey... thats nuts... you will top out at 10mph in 1st!!!
but you do have an auto, that should be super quick.
Aug 15, 2002 | 11:45 PM
Shooting for 10's? :D
Aug 16, 2002 | 12:13 AM
Go for it Mackey!! Had them in a '69 Z28 and that sucker absolutely destroyed just about everything that wanted to try it. Did run a Hemi Road Runner that showed me what it meant to be humble, but it had headers and gears.
Aug 16, 2002 | 12:49 AM
From: And on the fifth day, subpoenas were served to Obama senior staff
Re: 5.13 GEARS (bogus)
Sounds like the "Big Mac" gonna be running some big tires soon. Or he found out those heads like to run really high rpms. :jester
Aug 16, 2002 | 04:27 AM
I think you're heading in the direction of a solid rear axle.
Aug 16, 2002 | 08:24 AM
Re: 5.13 GEARS (M2001)
Mackey...do you drive this car to work everyday?
Aug 16, 2002 | 10:54 AM
Re: 5.13 GEARS (BBA)
:nono: NO ;)
Aug 16, 2002 | 12:58 PM
John, I have a friend that use to work for Dana. He says that if you know the right people at Dana they can custom make any gear set you want. Try to use one of you contacts at GM to get you a set made.
Also, you were the first person on this forum to recommend that I change gears. I just had 4.10's installed and love them.
Thanks You
Mike from Wentville GM.
[Modified by STL94LT1, 5:02 PM 8/16/2002]
Aug 16, 2002 | 02:23 PM
Re: 5.13 GEARS (STL94LT1)
That thing is really going to rocket out of the hole now. I hope it makes it ok from home to the track and back. That is a LOT of gear.
Aug 16, 2002 | 02:24 PM
Is this to make up for those 30" tall tires I saw you asking about?
Aug 16, 2002 | 05:53 PM
Cruise-In I Veteran
Cruise-In II Veteran
Mackey......do you think the Dana 44 can withstand such a low gear?
Aug 16, 2002 | 08:28 PM
See my post about a 4-link!!!!!!!!!!!!!!!!
Aug 18, 2002 | 12:13 AM
Re: 5.13 GEARS (Zora)
:confused: :confused: :confused:
Aug 18, 2002 | 12:28 AM
You will not get a custom gear made, but Dana makes it. All Dana 44 gears will work, but the downside is the 5.13 gear will have to have a sleeve welded on it like the early 4.09's did. They do not make a 5.13 for a super 44 which is what the Vette and the Viper has.
Aug 18, 2002 | 01:23 PM
Cruise-In I Veteran
