timing wire
Old May 26, 2015 | 09:10 PM
jimsmith's Avatar
jimsmith
Default timing wire
The wire that gets unplugged to check the timing shorted out on my manifold. What would get fried if anything? It threw a code immediately when it happened. I repaired the wire and no more codes showed up. It has a engine miss now. Any suggestions would be appreciated...thanks
Old May 27, 2015 | 01:38 AM
Cliff Harris's Avatar
Cliff Harris
Check your timing to make sure it is advancing. It should be roughly 20° at idle.
That wire disables the connection between the ECM and the ignition module that controls timing.
Old May 28, 2015 | 07:05 PM
Vett1990's Avatar
Vett1990
If your wire came disconnected you will have zero advance and a definite miss or pop out the TB during throttle input.
If your timing is correct? connect the wire, disconnect battery grond cable (to clear ECM memory), re-connect battery start engine and it should resume normal operation. It may take a few start cycles for the system re-learn normal.
To timing wire
