Driver's Side Window Stays Down
Old Jun 10, 2015 | 08:14 AM
  #41
antfarmer2's Avatar
antfarmer2
On my 94 it started pulling away at the top and I put two screws about two inches long at the top of the door pad front and back put them in at a slight angle and the inside door sweep hides them well. They work like hooks on the door frame and work like a champ. If your door sweeps are bad good time to replace and any bulbs.
Old Jun 10, 2015 | 10:43 AM
  #42
CVTLOPE's Avatar
CVTLOPE
Well
New driver's side PW switch turned up this morning.
Just tested & no change.
So its not the switch.
There is a clue though.
New switch did exactly what old one did.
ie, passenger's window goes up & down ok.
Driver's side window stays down. However, when I toggle it forward to go up, no noise, BUT, when I toggle it to go down, at the point of releasing the pulled back toggle for it to go back into the 'neutral position', there is a definite click coming from the dash, where I expect the PW Control Module to be.
Any one know their way around the PW Control Module?
Are there relays in there??
Next Diagnostic step is to pull apart the door to get to the window motor Terminal 'A'.
If that tests clean then its pull 1/2 the dashboard apart to get to the PW Control Module.
Mulling whether to go after the PW Control Module 1st, because of the clicking. Sounds like something opening fractionally then closing back up with a 'click'.
CVT
Old Jun 10, 2015 | 10:52 AM
  #43
antfarmer2's Avatar
antfarmer2
Originally Posted by CVTLOPE
Well
CVT
I still think it is a connection in or by the motor. the door pad is easy to take off just be gentle with the bezal can be tricky
Old Jun 10, 2015 | 12:47 PM
  #44
kg4fku's Avatar
kg4fku
Well
CVT
That is a good sign. That means the the module is working. That module is there to give the driver side window the "Auto down" or "express down" feature. There is a relay in that module along with a circuit called a latch circuit but only on the "down side".
On a side note concerning your switch - In order to make technical assumptions based on voltage output you must first know the input voltage. If you had measured the input voltage to the switch and then the output voltage of the switch you cold have made an assumption based on voltage drop. However, you only had one piece and assumed the system was providing 12v nominal to the switch. If that doesn't make sense then let me know and I will explain it differently.
Back on topic. I believe you will find a bad (broken) wire, a disconnected wire/plug or a bad window motor.
Where did you find a replacement switch?
Old Jun 10, 2015 | 01:40 PM
  #45
CVTLOPE's Avatar
CVTLOPE
Thanks for input.
Switch from Ebay Motors search.
If you need supplier let me know.
Its a repro. but works ok so far.
CVT
Old Jun 11, 2015 | 06:28 PM
  #46
kg4fku's Avatar
kg4fku
Any updates?
Old Jun 11, 2015 | 08:11 PM
  #47
CVTLOPE's Avatar
CVTLOPE
Any updates?
Was going to pull door panel today but needed to use car & held off.
Expect to start tomorrow.
Noticed 1 thing when out in car at midday - the driver's side switch was illuminated.
I thought that only occurred at night?
Is that a clue??
CVT
Old Jun 12, 2015 | 10:10 AM
  #48
CVTLOPE's Avatar
CVTLOPE
Okay
Door panel came off this morning.
A few missing screws, obviously it has been off some time in the past.
Next Diagnostic test is " Backprobe LH Power side window motor conn. with a Test Light from Term "A" to Ground. Does Test Light Light"?
Stuck on this one as I can see the top of the motor & plug but its in behind, & attached to, a sub-frame & can't get at the plug at the moment.
Anyone done this test & know what the trick is to get at Term "A"?
CVT
Old Jun 14, 2015 | 10:47 AM
  #49
CVTLOPE's Avatar
CVTLOPE
Okay
CVT
Bump.
Don't usually Bump, but need some thoughts on in situ Terminal A access.
CVT
Old Jun 14, 2015 | 12:07 PM
  #50
kg4fku's Avatar
kg4fku
Don't have an answer for you but I can recommend doing a search for window regulator removal or power window motor removal.
If that doesn't work then I suggest making a new thread with a title of maybe removing power window motor.
Most people will ignore threads that are this long as they believe the issue is already resolved.
Old Jun 14, 2015 | 12:43 PM
  #51
CVTLOPE's Avatar
CVTLOPE
Thanks.
As you can probably gather, I am trying to avoid having to demolish the inner door structure.
Looks somewhat inevitable at this stage
CVT
Old Jun 20, 2015 | 06:43 PM
  #52
CVTLOPE's Avatar
CVTLOPE
Thanks.
CVT
Been busy & just now getting back to it.
Read a few threads & articles on moving the 'downed" window up & where they couldn't readily get at the motor. If they could access the wires leading in - they cut the wires & put car jumper leads on to give 12V straight to the motor.
Tried that via a couple of fused jumpers, using a 12v lawn tractor battery I had handy, but nothing budged, nothing even tried to budge.
So, unless someone says a lawn tractor battery won't give enough amps to move a PW motor, I will be pulling the regulator & motor next for a closer look at the motor.
CVT
Old Jun 20, 2015 | 07:05 PM
  #53
antfarmer2's Avatar
antfarmer2
CVT
If you tried both ways it is the motor or the connection.
Old Jun 20, 2015 | 07:12 PM
  #54
CVTLOPE's Avatar
CVTLOPE
Yes, swapped wires after 1st shot.
CVT
