Do you flush???
Old Aug 16, 2002 | 10:12 AM
LT4BUD's Avatar
LT4BUD
Default Do you flush???
I just replace the 160 stat & did a TB bypass. I partially drained the coolant using only the radiator drain valve. The coolant visually looked clean & new, so I saw no need to consider a total drain, flush & refill. I just replaced the drained fluid with new 50/50 mix.
I now read in the new Corvette Fever in the article about changing a hose, that when they used a flush after observing clean coolant that they removed crude from the radiator. Should I have flushed?? Could this be the culprit in my loss of cooling system efficiency?
Old Aug 16, 2002 | 10:41 AM
ParadiseSD's Avatar
ParadiseSD
Default Re: Do you flush??? (LT4BUD)
It wouldn't hurt to flush! I didn't it a couple of weeks ago when I changed my waterpump, hoses, and thermostat. I went to Jiffy Lube.
