Ilde problems any suggestions?
Old Aug 16, 2002 | 01:31 PM
TALMADGE's Avatar
TALMADGE
Default Ilde problems any suggestions?
I have had this 88 Corvette for 4 months and have had this problem from day two. She wants to idle at 10rpms sometimes 11rpms. All I have to do is to barely touch the gas pedal and she goes down to 6rmps, where I like it. I can feel sometimes as the pedal is grabbing. I have lubricated the cable from the throttle. I think as though replacing the entire cable. Do you all think I am on the right track or not. This happens everytime I stop.
Any suggestions would be helpful. :blueangel:
Old Aug 16, 2002 | 02:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Ilde problems any suggestions? (TALMADGE)
Get some intake cleaner and clean the TB and throttle plates.
Remove the IAC under the TB and clean it's pintel and bore.
Then set base idle (instructions on my site) and the TPS base and WOT values.
If this doesn't cure the problem you may have some wear in the throttle plate shaft.
Old Aug 17, 2002 | 12:29 AM
vader86's Avatar
vader86
Yep, sounds like the IAC valve is dirty. Clean it and the whole Throttle body, check for vacuum leaks too.
Old Aug 18, 2002 | 11:11 AM
dlmeyers's Avatar
dlmeyers
Default Re: Ilde problems any suggestions? (vader86)
While you are in there around the Throttle Position Sensor, check to see if the voltage is consistent at idle. Move the throttle, note voltage, and see if it returns to original voltage. Good luck.
dlmeyers 90 coupe zf6 3 speed shocks
To Ilde problems any suggestions?
