speed sensor noise
I had asked about a transmission speed sensor noise. As it turned out the
noise was due to the two narrow pickup strips were too close to the gear in the transmission. [tried three new sensors with the same problem].
Note from the picture how the strips were actually disformed by the
the transmittion gear that was actually hitting these two small strips -
see picture.
Solution was to very carefully using a dremal tool, to cut these strips
down flush with the plastic housing. NO MORE NOISE and the speedometer works just fine.
Hope this helps someone.. Preacher putz Guess this might help.
The vette is a 96 LT1/Auto trans
