Injector Questions
I just took apart my intake to replace the lower intake with a ported one. As I was reassembling it, I decided to check everything while I had it apart.
My TPI was running very rough until it warmed up. I had seen somewhere that it may be a bad injector(s).
I ohm'd all 8, and got readings from 6.5-8.5- From what I have read, this is too low.
The way I did it was reading the resistance between the 2 pins where the plug goes. Did I do it correctly? I have never checked an injector before, so I could be totally wrong.
The engine in question is a 350 out of an '86 Vette. They're stock, so I was thinking of replacing them anyway.
If I do need new ones, do you have any suggestions as to what to buy, and where to get them from?
Thanks!
Thanks!
make it easy on yourself...call Jon at FIC....as far as I can tell, all on the forum respect his judgement and would give you the same advice...
http://www.fuelinjectorconnection.com/
92MOvette is offline Report Post
