How to remove Radiator (Late C4)
Old Apr 8, 2016 | 11:41 PM
JamesThatGuyy's Avatar
JamesThatGuyy
Last weekend I replaced my 91 coupe's radiator and bypassed the heater core at the same time (so many hoses and coolant... not the best call). If you know your radiator is going bad, change is ASAP! Mine ended up mixing the coolant and transmission fluid together, resulting in a long engine flush (hopefully no damage) and having to replace the transmission itself and many hoses. The entire mishap was about $1500.
Anyways the hardest bolts for me to reach were the ones that are located at the bottom of the radiator cover towards the front of the car. The trick was the right sized wrench and small hands xD if i rememer correctly, I used something along the lines of a 9/32" wrench for it. And when you disconnect the lower radiator hose, do know that there will be coolant, and it will be messy. Overall, it's a pretty straightforward process though
Old Apr 10, 2016 | 11:55 AM
Christi@n's Avatar
Christi@n
How many hours work to do all the job? I've just broken out mine and i have to replace it...
Old Apr 11, 2016 | 04:27 AM
JamesThatGuyy
my apologies for the late reply. Including the time it took to look for the tools I had misplaced, installing the new radiator took me an hour. If you are good at keeping your tools at hand, I doubt it would take more than thirty minutes
Old Apr 11, 2016 | 04:47 AM
Christi@n's Avatar
Christi@n
OH great this is a very good news
Old Sep 6, 2016 | 08:27 PM
MRPVette's Avatar
MRPVette
Very helpful Tom thanks did mine over the weekend.
Old Aug 13, 2017 | 08:30 PM
Komiller118's Avatar
Komiller118
pictures are not view-able..... information seems great, but no pics
Old Oct 8, 2017 | 12:49 PM
belairbrian's Avatar
belairbrian
Another great thread falls victim to photobucket
Old Oct 16, 2017 | 10:21 PM
GRKLGHTNG's Avatar
GRKLGHTNG
Anyway to maybe get the pictures posted on this thread again? Saw this about a year or so ago and thought it was VERY informative, especially with the pics. Planning to change out the rad this winter with a DeWitts, and could really use those pics
Old Oct 17, 2017 | 02:13 PM
belairbrian
I swapped mine yesterday. Really not much to it.
The hard part is the six screws down in the nose.
The radiator is just sitting in there. Once the upper shroud is removed and it is disconnected it pulls up and out.
While the shroud is off swap positions on the nut plates and screws in the nose. Makes removing it for radiator cleaning much easier.
I can't post all the pictures shown above but can take some pics and point out where everything is.
Is your car auto or manual trans?
Old Oct 17, 2017 | 05:10 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If one of you guys PM me (as a reminder) I'll DL all my pics from fotosuckit and re-upload them to the forum...
Old Oct 17, 2017 | 06:47 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Just did- thanks for the info
Old Oct 17, 2017 | 11:10 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't know if this has been posted before, (did a search, didn't find it), so I thought I's put up some pics here. Hope they help someone...
First thing, Start draining the coolant.
Reach under the frame from in front of the right tire, bend your had forward and it will practically hit the drain screw. There is a wonderful plastic "chute" that ensures all the coolant drains into one spot. No mess! My car gave up ~1.5 gallons, emptying the radiator, tank and hoses.
Name:  Drain Coolant_zpswwbgkjs3.jpg~original.jpeg
While coolant drains, remove air bridge and filter housing.
Name:  Remove Air Bridge_zpsr5o3wcxu.jpg~original.jpeg
Name:  Air Bridge Removed_zpsvnoojg3d.jpg~original.jpeg
Next, start removing all the shroud hardware. You'll need a 13mm socket, 10mm socket, a 7mm socket and assorted drivers, extensions etc. Starting on the driver's side, remove the two bolts holding the fan relays to the shroud, right here....
Name:  Drivers relays_zps6fnwpbmr.jpg~original.jpeg
Then remove these bolts and nuts, 10 and 13mm....
Name:  Drivers side_zpsyefdzqnc.jpg~original.jpeg
Next, looking down between the frame and the shroud, you can see both the air pump filter/inlet and the three, 7mm head bolts that need to come out....
Name:  Drivers side 7mm view_zpsorqcgw8g.jpg~original.jpeg
I chose to access those little bolts by removing the air pumps -only two bolts, one 13mm in the front, 10mm towards the rear, and two hose clamps for the air intake and discharge...
Name:  Smog pump_zps1t199er4.jpg~original.jpeg
Once the pump was out (very easy) I wiggled the air pump's intake out of there too....
Name:  Smog pump intake_zpsltdqoxuu.jpg~original.jpeg
With the air pump removed, access to those little screws was easy with a 1/4 drive, 7mm socket, wobble extension and drive, as seen here...
Name:  Drivers side 7mm removal_zps0z6devep.jpg~original.jpeg
  #33
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Moving over to the passenger's side, we do the same basic procedure, except that we don't need to move the air pump to access the small screws. Here is a blurry shot of me removing the small, 7mm head screws....
Name:  Passengers side 7mm_zpsxr63bwnr.jpg~original.jpeg
And then the upper, 10 and 13mm hardware here...
Name:  Passengers side _zpsqggf72tw.jpg~original.jpeg
The hose...
Name:  Bleed hose_zpsbcxcjbz4.jpg~original.jpeg
After that, there are 5, 10mm headed bolts along the top, that secure the fans to the shroud. Pull them out...
Three here on the passenger's side;
Name:  Passengers top_zps3t9pfcne.jpg~original.jpeg
And two on the driver's side;
Name:  Drivers top_zpsyazuxdit.jpg~original.jpeg
NOW, the shroud is ready to come up and out...however, there is a tab on the passenger's side that interferes w/the AC lines, so the shroud has to come out, lifting the driver's side first. Here is the Tab and AC lines where they'll interfere...
Name:  Tab AC interferance_zpsxqbzowla.jpg~original.jpeg
And here is a blurry pic of the shroud being lifted, driver's side first, up and out....
Name:  Lifting off shroud_zpsiok1bq9n.jpg~original.jpeg
That's the bulk of it. Once you've got the shroud out, it will look something like this:
Name:  Shroud removed_zps3hlpqfto.jpg~original.jpeg
All that is left is to remove upper and lower radiator hoses (coolant should be done draining by this point), and lift the old radiator up and out of it's rubber cradles. Piece of cake!
Name:  Radiator out_zps7u3pewbp.jpg
Old Oct 18, 2017 | 12:11 AM
  #34
GRKLGHTNG's Avatar
GRKLGHTNG
YOU ROCK!!! Thank you so very much!!! God bless!!!
Old Oct 18, 2017 | 12:19 AM
  #35
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Hey, thanks man. Hope that helps.
Old Oct 18, 2017 | 06:25 AM
  #36
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
didn't see it, sorry if it is here, but don't forget to turn those little screws around when putting them back in. A fellow member here reminded me of that after I had fought with them a long time getting them back in.
Old Oct 18, 2017 | 09:57 AM
  #37
pacoW's Avatar
pacoW
great post. I often wondered if there's room to drop an auxiliary fan in there and it looks like there's plenty of room for a low profile unit
To How to remove Radiator (Late C4)
Old Oct 23, 2017 | 08:46 PM
  #38
GRKLGHTNG's Avatar
GRKLGHTNG
Which little screws are you referring to?
Old Oct 23, 2017 | 08:47 PM
  #39
GRKLGHTNG's Avatar
GRKLGHTNG
It'll definitely help!!! Thanks again!!!
Old Oct 23, 2017 | 09:08 PM
  #40
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
He's talking about the little "three on each side", 7mm headed screws that hold the shroud to the frame. I found it quite easy to get to them w/a socket and a wobble extension as shown in my 9th and 10th pics down from the top.
