Stalling issues
Old Jun 8, 2015 | 02:16 PM
Brentwood Sooner's Avatar
Brentwood Sooner
Default Stalling issues
I have a 1996, when I washed the engine it would not start until the next day. I just drove it in the rain and it kept stalling out, has anyone else had this problem? I just changed the fuel pump and the gas is fresh. Sound like something is getting wet and causing these issues.
Old Jun 8, 2015 | 02:30 PM
antfarmer2's Avatar
antfarmer2
Yes you just learned a lesson do not get your opti wet they don't like it and are not cheap and easy put a fan on it and hope for the best.
Old Jun 8, 2015 | 02:38 PM
John A. Marker's Avatar
John A. Marker
If you really washed down the engine....you probably screwed the opti. Should not have done that. Big $$ to replace.
IF you can get it dry, it may end up working.
Opti is at front of the block with all the spark plug wires coming from it.
Old Jun 8, 2015 | 02:49 PM
Brentwood Sooner
It works fine now just when it gets wet it stalls out. How much does it cost to replace?
Old Jun 8, 2015 | 03:08 PM
John A. Marker
Friend had her 94 done at a good local shop and it was $1900 which also included a new coolant pump. It is recommended that you replace the pump when you replace the Opti.
Opti Spark ...Summit Racing lists the MSD at $496 and these is some question as to the reliability of this unit.
AC Delco water pump thru RockAuto is about $100.
Old Jun 8, 2015 | 07:30 PM
antfarmer2's Avatar
antfarmer2
It is wet when it gets wetter it stalls try to dry it ASAP you might get lucky.
Old Jun 8, 2015 | 07:45 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default 1996 Corvette
I have owned my 1996 since it was new and never washed the engine. Have driven through some heavy rain storms, only a couple in all the years and had to engine problems. The 1996 Corvettes have a vented opti that actually is connected the engine vacuum system and has air circulation through the opti to remove moisture, perhaps with more engine running time it will cure itself.
I believe the vacuum air through the opti started in 1995.
To Stalling issues
