'85 automatic won't release key from ignition
Old Jun 9, 2015 | 10:00 PM
Axelrod's Avatar
Axelrod
Default '85 automatic won't release key from ignition
Car was in storage for a few years. Put the key in the ignition. Now it won't come out. Twisted the wheel hard either direction.. run the auto trans selector back and forth and forcibly try to put it into park (it seemingly does go into "park) and no dice. The switch will not that extra smidge ot release the key. What gives?
Old Jun 9, 2015 | 10:38 PM
JD1964's Avatar
JD1964
Spray some WD40 down into the cylinder along side of the key and let it soak for a while. Maybe the tumbles are gummed up and holding the key. That, or get underneath and make sure the linkage is throwing the trans detent lever all the way into park position.
Old Jun 9, 2015 | 10:39 PM
antfarmer2's Avatar
antfarmer2
Had this happen on a 64 mustang the key was never taken out since new. It came out after gently turning the key back and forth while tapping it in and pulling it out.
Old Jun 10, 2015 | 04:16 PM
enventr's Avatar
enventr
Make sure the button on top of the shifter is fully extended out
Old Jun 10, 2015 | 04:34 PM
antfarmer2's Avatar
antfarmer2
did not think of that.
Old Jun 10, 2015 | 10:21 PM
Axelrod's Avatar
Axelrod
Thanks for the heads up guys. Will know more this weekend.
Old Jun 11, 2015 | 05:05 PM
ynk1121's Avatar
ynk1121
I don't know what year VATS started. 85 may pre-date it but if you have a pellet in the key do NOT start spraying anything down where the key is. The car measures the resistance of the pellet before it will let it start. Oil is going to mess with the reading and you'll add a second problem.
I had a Malibu that did this and it was the shifter at fault. Although the indicator showed it was in park, and the transmission behaved as though it was in park, something was sticking. When it did this the button had no resistance behind it. Jiggling the shifter would cause the shaft behind the button to lift and when the button felt normal and the key could be removed.
Old Jun 11, 2015 | 05:07 PM
ovrebo1's Avatar
ovrebo1
Slide hammer the tumbler out
Old Jun 11, 2015 | 10:26 PM
Axelrod's Avatar
Axelrod
Nothing was releasing the key. The center console had to be lifted from around the shifter.
The fix?
There is a release cable that connects from the shifter and goes to the steering column. This cable was seized up. It took quite a bit of WD40 and penetrating oil to loosen this up.
All good now!
Old Jun 11, 2015 | 10:31 PM
antfarmer2's Avatar
antfarmer2
The fix?
All good now!
Good job glade you got it.
To '85 automatic won't release key from ignition
