Here we go again
Old Jun 12, 2015 | 09:53 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Here we go again
As you may know I broke down last Sunday Which makes only 3 years since my last tow. After a few days I went to start her up and she started so I let her run until operating temp. At around 194 degrees the rpms started to roll and she quite and did not start again. It looks like a heat related problem and time to check the icm and the mounting grease[ forget what type it is] and I'm open to any new suggestions.
Old Jun 12, 2015 | 10:02 AM
antfarmer2's Avatar
antfarmer2
also let it cool down then see if it starts. Then when hot if no start change your coil too.
Old Jun 12, 2015 | 02:25 PM
kimmer's Avatar
kimmer
Yeah I'v gone through this before and it seemed like 50% of the icm did not work correctly. I also think I am losing my memory dont remember what type of grease to use.
Old Jun 12, 2015 | 03:19 PM
Pete919's Avatar
Pete919
I used heat sink grease from radio shack. No problems.
Old Jun 12, 2015 | 03:55 PM
kimmer's Avatar
kimmer
No more Radio Shacks around here.
Old Jun 12, 2015 | 05:13 PM
antfarmer2's Avatar
antfarmer2
Any computer store. thermal grease
Old Jun 12, 2015 | 05:20 PM
crowz's Avatar
crowz
Artic silver heat sink compound. Newegg.com sells it. I keep it on hand for computer cpu heat sinks but works great on the car stuff when needed.
Old Jun 12, 2015 | 11:22 PM
1993C4LT1's Avatar
1993C4LT1
I like to see if it's opti or not when an LT1 turns off on me. Connect noid light to fuel injector number one. While cranking, if no light, opti is bad. But yes, I'd re apply the thermal grease.
Old Jun 13, 2015 | 09:53 AM
kimmer's Avatar
kimmer
It's not the opti, I can go out and it will start right up. When it gets hot[operating temp] the rpms start to roll and she quits and won't start until she cools down. When my opti took a nose dive it would never start.
Old Jun 13, 2015 | 10:06 AM
1993C4LT1's Avatar
1993C4LT1
That makes sense. When my opti's died I'd have to wait like 5 or 10 mimutes for it to start up. So yeah, sounds like ICM or coil
Old Jun 14, 2015 | 03:32 PM
kimmer's Avatar
kimmer
I just took off the old coil and icm and I must say there was not much grease on the head or the back of the icm so will try some new ones I have. As far as the grease goes is die electric ok or should I get a heat sink product?
Old Jun 14, 2015 | 03:49 PM
ToniJ1960's Avatar
ToniJ1960
Myself I would for sure get thermal grease and some people say use a thick coat, but usually you want a thin coat just to fill in minor irregularities, since the grease doesn't conduct heat as well as metal will. Too thick you could be in the same boat as none.
Old Jun 14, 2015 | 03:56 PM
kimmer's Avatar
kimmer
I thank you.
Old Jun 14, 2015 | 04:02 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It COULD be the opti. It's more likely that it's the ICM...but the opti can die from heat, and I PROVED IT HERE.
Video here:
If you have a tach signal when it's hot and won't start, either checking by injector pulse as mentioned above, tech reading on a scan tool, or just watching the tach while cranking, then the Opti is not the problem.
Old Jun 14, 2015 | 06:01 PM
kimmer's Avatar
kimmer
Wow that was a great write up and a lot of work. I already have the icm on a shelf so I will try that first. If still a problem I will follow your procedure. Funny you brought up the plug connectors for the coil/icm because last time I had this problem it was the black plug that was bad, replaced it and has been fine until now. Thanks again.
Old Jun 14, 2015 | 06:10 PM
ToniJ1960's Avatar
ToniJ1960
Video here:
large - YouTube
I was going to say something about Tom coming in soon on that one
Old Jun 16, 2015 | 03:24 PM
STEVEN13's Avatar
STEVEN13
When I was trying to figure out my problem I just connected a new ICM without mounting it. Did the same with the coil. Connected them with the engine at running temp. In both cases it did not fix my problem. In my case it was the wires and plugs (if you followed my thread).
Good luck and please report your fix.
To Here we go again
Old Jun 19, 2015 | 06:38 PM
kimmer's Avatar
kimmer
Update. Well I removed the old icm and cleaned everything up. Put heat sink grease behind the new icm and on the head, turned it on and let it run & run & run. It idled at operating temp for about a half a hour or until my wife shouted to me to shut it off because she was trying to sleep. So I took it out on the road and everything seems fine for now. I'll cross everything I can cross on my next drive.
Old Jun 19, 2015 | 06:46 PM
antfarmer2's Avatar
antfarmer2
glade you got it
Old Jun 19, 2015 | 08:16 PM
1993C4LT1's Avatar
1993C4LT1
Cool! Now just enjoy the car
