Broken vacuum line fitting
Old Jun 14, 2015 | 10:04 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Broken vacuum line fitting
While trying to connect a fuel pressure gauge I snapped a vacuum line fitting by the passenger side fuel rail.
It's a 92 that has a miss and since I've retired I'm finally able to spend some time on fixing it.
The fitting has thee lines connected to it. Any know if it performs a function other than connecting the three lines? From the looks of it it may contain a valve of some sort. Can't find a diagram online that describes it or a part number.
Old Jun 14, 2015 | 10:56 PM
ex-x-fire's Avatar
ex-x-fire
Looks like the heater-a/c check valve, it's a one way valve the goes to vacuum tank that supplies vacuum to operate the blend doors.
Old Jun 14, 2015 | 11:16 PM
Opihi59's Avatar
Opihi59
Bonehead
Nice job on the pointy yellow arrow. One of these days, I'll have to learn how to do that.
Here you go.
That's a NAPA part number, so check your local store. Costs about $5. And HERE'S the only reason that I know that info.
Old Jun 14, 2015 | 11:45 PM
Blue 92's Avatar
Blue 92
Thanks guys. I'll do a NAPA run tomorrow, hopefully they'll have one. Strange thing is I broke the line when the car was in the driveway. It seemed to run better with the line broken than it normally has been......
As to the yellow arrow the secret is MS Paint....
Old Jun 15, 2015 | 12:42 AM
Dt86's Avatar
Dt86
Those check valves dry out and break easily. Arrows and circles are always a plus!
Old Jun 18, 2015 | 01:08 AM
Blue 92's Avatar
Blue 92
Found it at Advance Auto. He cross referenced the NAPA part number.
Now to dig the broken piece out of the line.
Old Jun 18, 2015 | 02:11 AM
Opihi59's Avatar
Opihi59
Bonehead
Post us up that Advance Auto part number so we can increase forum knowledge on this part.
Old Jun 19, 2015 | 12:24 AM
Blue 92's Avatar
Blue 92
Dorman "Help!" parts. Item # 47150
Old Jun 19, 2015 | 09:10 AM
jimmers's Avatar
jimmers
I'm in need of one of these too. Thanks for posting the part numbers!
Old Jun 19, 2015 | 10:55 AM
twin540's Avatar
twin540
I like these post. Quick help
To Broken vacuum line fitting
