WATER PUMP SENSOR???
Old Aug 17, 2002 | 10:40 AM
Voltech_LT4's Avatar
Voltech_LT4
Cruise-In IV Veteran
Default WATER PUMP SENSOR???
on the front of my 96's water pump im replacing, there is a screw with a plug in with a two wire connector.... (front right bottom of the water pump if looking at it from the front.) Is that the water pump temp sensor? Im asking because I dropped the old water pump and it cracked a little, could probably still use it but would rather replace it right away before I put the new water pump back in... oh btw...those last two screws on the water pump are a BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEPPP PPPP~! :cuss :cuss :lol: :cheers:
[Modified by Voltech_LT4, 9:41 AM 8/17/2002]
Old Aug 17, 2002 | 10:45 AM
LT4BUD's Avatar
LT4BUD
Default Re: WATER PUMP SENSOR??? (Voltech_LT4)
If it is the ECT sensor they only cost about $10 at an autoparts store. This is the one for engine PCM. The one for gauges is located on right side of block. Make sure you ask for the right one, one is 2 wire & the other sensor is 1 wire.
[Modified by LT4BUD, 8:47 AM 8/17/2002]
Old Aug 17, 2002 | 04:08 PM
ittlfly's Avatar
ittlfly
If it's the same on your 96 as my 92, it's a coolant temp. sensor. (CTS)
Old Aug 17, 2002 | 04:13 PM
Voltech_LT4
got it, glad the parts store had it in stock, cost me $7.99 i think.
was a coolent temp sensor they said...
thanks for all your help !
vr,
volt
To WATER PUMP SENSOR???
