L83 questions
Old Jun 17, 2015 | 06:33 AM
phucking-low's Avatar
phucking-low
Default L83 questions
Lets start by saying i have a 84 corvette with the stock L83 350 now with a carburetor
first question i have, is there anything wrong with the L83 block itself. Reason i ask is i am planning to buy a 383 stroker kit and put it in this block. This is a way cheaper option then buying a already assembled 383 short block from like blue print, and with the money i save i can buy the 383 kit with forged internals.
Second is about cylinder heads in general. I will use the stock L83 heads as a reference, the stock heads have a 76mm combustion camber and with the stock block is 9:1 compression. I see people buying 72mm and smaller combustion camber heads and increasing the compression ratio. Now my question, wouldnt a bigger combustion camber make more power over a smaller one? For example since i am building a new motor and can choose what pistons i want to control my compression ratio, wouldnt i want to stay with a 76mm bigger combustion camber and buy domed pistons to up the compression ratio?
Old Jun 17, 2015 | 07:26 AM
ex-x-fire's Avatar
ex-x-fire
The short block L83 as a whole wasn't to bad for an early 80s engine, it had forged pistons, compression ratio of 9.0, heavy duty oil pump.
Me, I'd find a later block to build up because they are made for factory roller cams, the retrofit cam & kits cost a lot more.
Do your homework when choosing pistons & cylinder heads (& cam), you don't want too much compression that won't allow you to run pump gas.
Old Jun 17, 2015 | 08:37 AM
phucking-low
I dont think i will make enough power to need a roller cam motor, as of now i have swapped it to a carb and have a flat tappet comp cams 270H with matching comp cams valve springs and lifters and i went ahead and bought the comp cams high energy push rods. Next is to buy the eagle 383 stroker kit and then aluminum heads. How high of compression can be run on pump gas?
Old Jun 17, 2015 | 10:06 AM
PatternDayTrader's Avatar
PatternDayTrader
Imo don't go past 9.5 to 1 if your running a carb.
Old Jun 18, 2015 | 02:31 PM
TLS_Addict's Avatar
TLS_Addict
Depends on. few things. If he is going to aluminum heads I say go for more. But I never had a problem running over 10:1 in a street car with iron heads.
Old Jun 18, 2015 | 03:11 PM
phucking-low
i am looking at getting the edelbrock e series aluminum heads.
Old Jun 18, 2015 | 09:17 PM
TLS_Addict's Avatar
TLS_Addict
I think some 64cc heads would land you around 10.2:1 if my memory serves me correct on an L83, but don't quote me.
Old Jun 18, 2015 | 10:16 PM
ghoastrider1's Avatar
ghoastrider1
the L-83 block is basicly the same block made since 1955. Nothing wrong with it for your ap. The heads on your 84 , well,to be honest, suck. I f I am thinking correctly, the larger cc chambers will slow down the speed of the incoming air. That's why vortec heads work so well with the 64 cc. All that stuff on top will be choked down if you run stock exhaust.
Old Jun 18, 2015 | 10:21 PM
phucking-low
For exhaust I am running headman full lenght headers w/3" collectors, no cat, MagnaFlow x pipe 3", all 3" piping, back to 3" MagnaFlow staight through mufflers and I added the LT1 style corvette exhaust tips to them
Old Jun 18, 2015 | 10:40 PM
Drew95's Avatar
Drew95
I want to sub myself on this just to see how this plays out.
3" out from collectors and no cats on an L83. I can't imagine how anyone could stand next to that car without a bottle of visine..... but let's see.
Old Jun 19, 2015 | 05:19 AM
phucking-low
how is it any different from any old chevy 350 70's muscle car that didnt come with cats from the factory and people run 3in exhaust on them all the time.
Old Jun 19, 2015 | 08:04 AM
Drew95's Avatar
Drew95
Do they, though?
I don't know - just seems big for a 9:1 compression motor.
Old Jun 19, 2015 | 09:15 AM
TLS_Addict's Avatar
TLS_Addict
If it is pig rich at idle then yes, it wouldn't be good, but proper tuning shouldn't make your eyes dry/hurt/itch.
I am starting a cross-fire build in the near future. I am.sure I will have a load of questions too. Lol
Old Jun 19, 2015 | 09:43 AM
phucking-low
No worries because its looking like with the new heads and 64mm combustion cambers I will be around that 10.2:1 compression area. So don't go buying your visine just yet.
Old Jun 19, 2015 | 09:45 AM
Drew95's Avatar
Drew95
Roger that.
Old Jun 19, 2015 | 10:23 AM
TLS_Addict's Avatar
TLS_Addict
Why not put a carb in top of a TPI intake? Hahah
To L83 questions
