overheating
Old Jun 17, 2015 | 02:12 PM
gspur1's Avatar
gspur1
8th Gear
Default overheating
got a 85 vette at what temp is the danger point and what is normal temp, around 40 to 45 mph it runs 195 to 205 when i get into a town it goes up to 225 to 235 , antifreeze ok, at what point do i worry.
thanks gspur1
Old Jun 17, 2015 | 02:16 PM
eldertek's Avatar
eldertek
I have a 91.
Same temps here.
235 use to concern me, normal around town.
Old Jun 17, 2015 | 02:22 PM
antfarmer2's Avatar
antfarmer2
Pull the top radiator shrould off and clean inbetween
Old Jun 17, 2015 | 02:45 PM
eldertek's Avatar
eldertek
Can a diy guy do that?
Simple?
Old Jun 17, 2015 | 02:51 PM
antfarmer2's Avatar
antfarmer2
Simple?
Yes the hardest part on mine was the three 7mm on either side use a flat ratchet wrench with tape if yours has them. They are fast vacumme cleaners clean and flush good.
Old Jun 17, 2015 | 03:58 PM
vader86's Avatar
vader86
Those temps are normal, and you have iron heads, so you can handle more heat than the aluminum head without danger of head gaskets, but if it gets to 250-260 I'd pull over and shut it off.
Old Jun 17, 2015 | 04:03 PM
antfarmer2's Avatar
antfarmer2
but there is still 30 years of crap in there.
Old Jun 17, 2015 | 04:29 PM
unihusker's Avatar
unihusker
excellent...good to know. thanks!
Old Jun 17, 2015 | 07:21 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
doing only that wouldn't clean something like mine was. Radiator should come out to do it right
To overheating
