rear end wobble. What do I need to replace?
Does anyone have experience with working on these pieces? I am looking to see what I am up against. Is this something I can leave until this winter to tackle? Not looking to down the car unless it is a quick (weekend) fix. That means parts are available. Does NAPA or Discount have these parts in stock?
I heard there is an aftermarket solution as well. Does anyone have a recommendation and a place to order from?
One last question. I assume that I will need a complete alignment after this. How bad is that going to be to find someone to do that?
thanks for any replies
i replaced the wheel hubs at the same time.
get under the car and start yoinking on things to see what is loose. might be the axle nut. and safety first. make sure you have many jackstands as backup in cae one fails.
Thanks for the reply and info.
Check all the parts but pay close attention to the u-joints.
