Air pump eliminator question.
Old Aug 17, 2002 | 06:06 PM
ZAD54's Avatar
ZAD54
Default Air pump eliminator question.
I just received my kit and had a question about the check valves. The instructions say to "Be sure to leave the Check Valves". Since I am removing the cats and going to a true dual exhaust, is there really any need to leave the valves. I think not, but I'd like to know from some of you that have installed this kit. Thanks :seeya
Old Aug 17, 2002 | 06:45 PM
Rob90's Avatar
Rob90
Default Re: Air pump eliminator question. (ZAD54)
Might have to leave them until you get those headers you want. If it is the check valves I think your talking about. You would have to cut the air tubes off and plug them with some thing. I have herd of some people putting screws in the holes. At least with the check valves on you can put the rubber caps over them or go to the parts store and get a pipe fittng to screw on the end
Old Aug 17, 2002 | 11:47 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Air pump eliminator question. (Rob90)
I took the check valves off and put on steel pipe caps from Lowes.
1/2 inch thread I believe.Cost maybe a buck.
I also removed the cat. air feed pipe and plugged that under the car,plus removed some misc. plumbing in front of the engine.
Old Aug 18, 2002 | 12:45 AM
LeadFoot's Avatar
LeadFoot
Lose 'em
Old Aug 18, 2002 | 09:41 AM
ZAD54's Avatar
ZAD54
Well actually I was only talking about the check valve on the converter air tube. NOw that the tube is going to be gone with the converter, I don't guess there will be anything to hook it to anyway. Thinking about it now, that was a silly question for me to ask huh? :lol:
Old Aug 18, 2002 | 02:18 PM
Aggravated4life
Hey Zad,
When I removed the air tube to the main cat,I reused the rubber hose connector and put a fact screw in it and clamped it down at the cat. in place of the old tube and it held on nicely.Didnt need to remove the main cat for that so it remains "legal" to some extent.
Just thought id pass this along in case you decide to leave the cat in place but need to plug the hole down there.
To Air pump eliminator question.
